10-30-2016, 11:27 | #1 (permalink) |
Freak Poster Join Date: Aug 2005 Location: tamil nadu Age: 38
Member: 170244 Status: Offline Thanks Meter: 418 | j500g 6.0.1 after unlock still locked i have j500g 6.0.1 unlock ok but still ask code pls help me log UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Unlock' button for direct unlock. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-J500G Selected port: COM47 SAMSUNG Mobile USB Serial Port Software version: 26.8 Reading phone info... Reading IMEI... OK IMEI: 352311078905507 Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.26.8 log UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Unlock' button for direct unlock. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-J500G Selected port: COM47 SAMSUNG Mobile USB Serial Port Software version: 27.0 Reading phone info... Reading IMEI... ok IMEI: 352311078905507 Unlocking... error (0) Done with Samsung Tool PRO v.27.0 my set vertion ap:J500GXXUIBPI3 CP:J500GXXUIBPI2 CSC: J500D0LBIBPI2 MODEL:SM-J500G/DS pls help me team unlock this mobile thenks |
