06-26-2016, 14:33 | #1 (permalink) |
Major Poster Join Date: Oct 2014
Member: 2268654 Status: Offline Thanks Meter: 0 | J500G with IMEI /01. Can't write CERT Operation: Write CERT Selected model: SM-J500G Selected port: COM66 SAMSUNG Mobile USB Serial Port Software version: 25.8 Checking certificate file... OK KEY ID: 0338 Waiting ADB device... OK Reading phone info... Model: SM-J500G Android version: 5.1.1 Product code: Not Active Phone version: J500GXXU1APA2 PDA version: J500GXXU1APA2 CSC version: J500GOLB1AOK2 CSC country code: INDONESIA CSC sales code: XID HW version: Phone S/N: Modem board: MSM8916 RF cal date: 2015.09.09 IMEI: Initialization AT RIL... OK Bypass MSL... error (2) First reset MSL Done with Samsung Tool PRO v.25.8 |
06-28-2016, 08:16 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,529 | Quote:
07-03-2016, 09:17 | #3 (permalink) |
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Offline Thanks Meter: 1,776 | Operation: Write CERT Selected model: SM-J500G Selected port: COM34 SAMSUNG Mobile USB Serial Port Software version: 25.8 Checking certificate file... OK KEY ID: 0338 Waiting ADB device... OK Reading phone info... Model: SM-J500G Android version: 5.1.1 Product code: Not Active Phone version: J500GXXU1AOK1 PDA version: J500GXXU1AOL1 CSC version: J500GOLB1AOK2 CSC country code: MALAYSIA CSC sales code: XME HW version: Phone S/N: RV8H401TBPW Modem board: MSM8916 RF cal date: 2016.04.05 IMEI: Initialization AT RIL... OK Bypass MSL... error (2) First reset MSL Done with Samsung Tool PRO v.25.8 |
07-03-2016, 10:46 | #6 (permalink) |
Member: 2556542 Status: Offline Thanks Meter: 1,776 | RSET MSL FIRST BUST SAME PROBLEM Operation: Write CERT Selected model: SM-J500G Selected port: COM34 SAMSUNG Mobile USB Serial Port Software version: 25.8 Checking certificate file... OK KEY ID: 0338 Waiting ADB device... OK Reading phone info... Model: SM-J500G Android version: 5.1.1 Product code: Not Active Phone version: J500GXXU1AOK1 PDA version: J500GXXU1AOL1 CSC version: J500GOLB1AOK2 CSC country code: MALAYSIA CSC sales code: XME HW version: Phone S/N: RV8H401TBPW Modem board: MSM8916 RF cal date: 2016.04.05 IMEI: Initialization AT RIL... OK Bypass MSL... error (2) First reset MSL |
07-06-2016, 07:29 | #8 (permalink) | |
Member: 2556542 Status: Offline Thanks Meter: 1,776 | J500g bypass msl error solve Quote:
Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-J500G Selected port: Software version: 25.8 Checking certificate file... OK KEY ID: 0338 Waiting ADB device... OK Reading phone info... Model: SM-J500G Android version: 5.1.1 Product code: Not Active Phone version: J500GXXU1AOJ2 PDA version: J500GXXU1AOJ1 CSC version: J500GOLB1AOJ1 CSC country code: THAILAND CSC sales code: THL HW version: Phone S/N: RV1GB14K39K Modem board: MSM8916 RF cal date: 2015.11.20 IMEI: Initialization AT RIL... OK Bypass MSL... OK Checking for compatible phone and cert... OK Phone KEY ID: 0338 Writing CERT... OK Checking CERT status... OK Rebooting phone... OK Done with Samsung Tool PRO v.25.8 | |
07-06-2016, 07:30 | #9 (permalink) |
Member: 2556542 Status: Offline Thanks Meter: 1,776 | CONTACT WITHE ME ([email protected]) |
07-11-2016, 12:40 | #10 (permalink) |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,276 | Reading phone info... Reading IMEI... OK IMEI: 0 Reseting MSL security... OK Reseting... OK Reset MSL done Done with Samsung Tool PRO v.25.9 Checking certificate file... OK KEY ID: 0338 Waiting ADB device... OK Reading phone info... Model: SM-J500G Android version: 5.1.1 Product code: Not Active Phone version: J500GXXU1AOG1 PDA version: J500GXXU1AOG4 CSC version: J500GOLB1AOG5 CSC country code: MALAYSIA CSC sales code: XME HW version: Phone S/N: RV8G81PE3XR Modem board: MSM8916 RF cal date: NONE IMEI: Initialization AT RIL... OK Bypass MSL... error (2) First reset MSL Done with Samsung Tool PRO v.25.9 |
07-11-2016, 12:41 | #11 (permalink) |
Member: 1626780 Status: Offline Thanks Meter: 1,276 | |
