06-04-2017, 06:01 | #1 (permalink) |
No Life Poster Join Date: Aug 2010 Location: SearchinG ... Age: 39
Member: 1369772 Status: Offline Thanks Meter: 297 | J500H 6.0.1 Write Cert and Msl reset error !! Write Cert Failed BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-J500H Selected port: COM25 SAMSUNG Mobile USB Serial Port Software version: 28.2 Checking CERT file... Ok KEY ID: 0241 Waiting ADB device... Please, allow USB debugging on phone... Ok Reading phone info... Model: SM-J500H Android version: 6.0.1 Product code: SM-J500HZKDBNG Phone version: J500HXXU2BQC1 PDA version: J500HXXU2BQC1 CSC version: J500HODD2BQC1 CSC country code: Bangladesh CSC sales code: BNG HW version: MP 0.400 Phone SN: 00000000000 Modem board: MSM8216 Security patch: 2017-03-01 RF cal date: 2015.08.04 IMEI: Writing AT RIL... Ok Initialization AT RIL... root required Checking Super user right... true Initialization AT RIL... Ok Bypass MSL... error (2) First reset MSL Done with Samsung Tool PRO v.28.2 Reset MSL Eror !!! REPAIR INSTRUCTIONS: Activate Diagnostic Port: 1. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Select device in ADB settings. 2. Press 'Activate Diag' button. Reset EFS, Disable Factory Mode: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. 6. If you have yellow table on your device screen, then press 'Disable Factory Mode' button. Wipe EFS/NVM: If you have 'IMEI null/null' or 'Phone baseband unknown' errors, Then you can try to repair this errors with this function. 1. Power on phone in download mode (turn off phone, hold Volume Down + Home + Power). 2. Connect USB cable, install drivers if needed. 3. Press 'Wipe EFS/NVM' button to deactivate security. 4. Wait till phone reboot. Operation: Reset MSL Selected model: SM-J500H Selected port: COM25 SAMSUNG Mobile USB Serial Port Software version: 28.2 Reading phone info... Reading IMEI... Ok IMEI: 353505070109997 Reseting MSL security... error (1) Done with Samsung Tool PRO v.28.2 |
