03-15-2016, 22:33 | #1 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Arizona Age: 38
Member: 630795 Status: Offline Thanks Meter: 177 | J500h Cert write problem i was trying to repair imei by writing new cert but i got error Bypass MSL... error (2) Code: 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-J500H Selected port: COM35 SAMSUNG Mobile USB Serial Port Software version: 23.9 Checking certificate file... OK KEY ID: 0241 Waiting ADB device... OK Reading phone info... Model: SM-J500H Android version: 5.1.1 Product code: Not Active Phone version: J500HXXU1AOI1 PDA version: J500HXXU1AOI1 CSC version: J500HOXE1AOI1 CSC country code: Russia CSC sales code: SER HW version: Phone S/N: 00000000000 Modem board: MSM8216 RF cal date: NONE IMEI: Initialization AT RIL... OK Bypass MSL... error (2) First reset MSL Done with Samsung Tool PRO v.23.9 i try to change so many firmwares with and without root also tried the step by step tutorial by ashraf but no success also changed three Cert files but in vain any suggestions ? |
03-16-2016, 00:08 | #2 (permalink) |
No Life Poster Join Date: Apr 2014 Location: tripoli,libya Age: 36
Member: 2175357 Status: Offline Sonork: QQ:2157039171 Thanks Meter: 453 | According to your logs you need rest msl 1. root with cf-autoroot 2. update supersu in google play 3. install twrp manager from google play 4. flash recovery (twrp) with twrp manager 5. install busybox (using twrp manager or google play. 6. Fix permissions in recovery 7. Try wiping EFS. if you got nv backups, mark to not make new ones as it takes some time. 8. check if imei is gone, if not, restart phone and try again. ( It took 3 restarts for me) 9. write new cert. After you can hard reset to clean your phone or reflash with stock rom. Try this, I Google it, I don't try it before and write cert files It didn't come to my shop smiller. Conditions, Sent from my HTC One X using Tapatalk |
The Following User Says Thank You to helpo For This Useful Post: |
03-16-2016, 00:14 | #3 (permalink) |
Member: 630795 Status: Offline Thanks Meter: 177 | thanx bro i am rooted already also msl resetting is done successfully so many times but still the same error my konx is 0*1 is this has any thing to do with that ? |
