01-22-2016, 16:29 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | j500h reset msl Code: Operation: Write CERT Selected model: SM-J500H Selected port: COM185 SAMSUNG Mobile USB Serial Port Software version: 24.1 Checking certificate file... OK KEY ID: 0241 Waiting ADB device... OK Reading phone info... Model: SM-J500H Android version: 5.1.1 Product code: SM-J500HZWDPAK Phone version: J500HXXU1AOH2 PDA version: J500HXXU1AOH2 CSC version: J500HOJV1AOH4 CSC country code: PAKISTAN CSC sales code: PAK HW version: MP 0.400 Phone S/N: RV1G91BTNYK Modem board: MSM8216 RF cal date: 2015.09.12 IMEI: Initialization AT RIL... OK Bypass MSL... error (2) First reset MSL Done with Samsung Tool PRO v.24.1 |
The Following User Says Thank You to zishhaider For This Useful Post: |
01-23-2016, 12:20 | #2 (permalink) |
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | Done Code: Operation: Write CERT Selected model: SM-A300H Selected port: COM185 SAMSUNG Mobile USB Serial Port Software version: 23.9 Checking certificate file... OK KEY ID: 0241 Waiting ADB device... OK Reading phone info... Model: SM-J500H Android version: 5.1.1 Product code: SM-J500HZWDPAK Phone version: J500HXXU1AOH2 PDA version: J500HXXU1AOH2 CSC version: J500HOJV1AOH4 CSC country code: PAKISTAN CSC sales code: PAK HW version: MP 0.400 Phone S/N: RV1G91BTNYK Modem board: MSM8216 RF cal date: 2015.09.12 IMEI: Incorrect model selected. This may damage your phone. Continue? Yes Initialization AT RIL... OK Bypass MSL... OK Checking for compatible phone and cert... OK Phone KEY ID: 0241 Writing CERT... OK Checking CERT status... OK Writing Slave CERT... OK Checking Slave CERT status... OK Rebooting phone... OK Done with Samsung Tool PRO v.23.9 |
01-23-2016, 13:34 | #4 (permalink) |
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | Btw I had tried following files too in case you still got error do following procedure and try it after that. http://forum.gsmhosting.com/vbb/f453...-step-2029691/ |
01-04-2017, 16:31 | #5 (permalink) |
Freak Poster Join Date: Dec 2007 Location: bangladesh, chittagong
Member: 648453 Status: Offline Thanks Meter: 82 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-J500H Selected port: COM214 SAMSUNG Mobile USB Serial Port Software version: 27.7 Checking CERT file... Ok KEY ID: 0241 Waiting ADB device... Ok Reading phone info... Model: SM-J500H Android version: 5.1.1 Product code: SM-J500HZDDMID Phone version: J500HXXU1AOI1 PDA version: J500HXXU1AOI1 CSC version: J500HOJV1AOI2 CSC country code: Iraq CSC sales code: MID HW version: MP 0.400 Phone SN: RV1H410LYBB Modem board: MSM8216 RF cal date: 2016.04.21 IMEI: Writing AT RIL... Ok Initialization AT RIL... Ok Bypass MSL... error (2) First reset MSL Done with Samsung Tool PRO v.27.7 |
