07-13-2017, 17:20 | #1 (permalink) |
Freak Poster Join Date: Mar 2016 Location: HUAWEI
Member: 2548753 Status: Offline Thanks Meter: 256 | J510FN unlock Failed logs: Operation: Read Codes via Server Selected model: SM-J510FN Selected port: COM85 SAMSUNG Mobile USB Serial Port Software version: 28.7 Checking Login and Password... OK Ballance: 50 crd. Waiting ADB device... OK Reading phone info... Model: Android version: Product code: Phone version: PDA version: CSC version: CSC country code: CSC sales code: HW version: Phone SN: Chip name: Modem board: RF cal date: IMEI: Incorrect model selected. This may damage your phone. Continue? Yes Detected modem type currently is not supported () Done with Samsung Tool PRO v.28.7 |
07-13-2017, 17:24 | #2 (permalink) |
Member: 2548753 Status: Offline Thanks Meter: 256 | Checking Login and Password... OK Ballance: 50 crd. Waiting ADB device... OK Reading phone info... Model: SM-J510FN Android version: 6.0.1 Product code: SM-J510FZKUPHN Phone version: J510FNXXU1API5 PDA version: J510FNXXU1APJ3 CSC version: J510FNPHN1APJ1 CSC country code: The Netherlands CSC sales code: PHN HW version: MP 0.300 Phone SN: RF8J20V1JTR Chip name: MSM8916 Modem board: MSM8916 Security patch: 2016-10-01 RF cal date: 2017.02.08 IMEI: Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Initialization zTool... error (0) Done with Samsung Tool PRO v.28.7 |
07-13-2017, 17:43 | #3 (permalink) |
Member: 2548753 Status: Offline Thanks Meter: 256 | UNLOCK INSTRUCTIONS: Unlocking with original MSL code: 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will apear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Read Codes via Server Selected model: SM-J510FN Selected port: COM85 SAMSUNG Mobile USB Serial Port Software version: 28.7 Checking Login and Password... OK Ballance: 50 crd. Waiting ADB device... OK Reading phone info... Model: SM-J510FN Android version: 6.0.1 Product code: SM-J510FZKUPHN Phone version: J510FNXXU1API5 PDA version: J510FNXXU1APJ3 CSC version: J510FNPHN1APJ1 CSC country code: The Netherlands CSC sales code: PHN HW version: MP 0.300 Phone SN: RF8J20V1JTR Chip name: MSM8916 Modem board: MSM8916 Security patch: 2016-10-01 RF cal date: 2017.02.08 IMEI: Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM4 detected Reading data from phone... error (3) Done with Samsung Tool PRO v.28.7 |
07-25-2017, 02:21 | #7 (permalink) |
Freak Poster Join Date: Jan 2007 Location: <Al hind al Garbiyya> Barbados
Member: 430155 Status: Offline Thanks Meter: 40 | ----------------------------------------------------------------------------------- To connect SM-J700H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-G357FZ phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-J510FN phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-J510FN Reset Screen Lock operation for SM-J510FN will delete all user data on the phone (contacts, pictures and others)! Connecting to server... Could not connect to the server! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-J510FN into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Custom section... Custom section has been written successfully. Reset Screen Lock successfully completed. Performed by 2.5.6 Software version. |
