06-10-2019, 17:59 | #1 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,802 | Samsung Galaxy J3 pro 2017 j330f efs read done Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. BE CAREFULL! IF YOU GET KNOX WARRANTY VOID STATUS DURING ROOT OR ANY OTHER PROCEDURE, THEN YOU WILL NOT BE ABLE UNLOCK THIS PHONE IN FUTURE! 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. Read certificate operation: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't use this function. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read CERT' button to read certificates. Operation: Info Selected model: SM-J330F Software version: 36.2 Searching Samsung modem... detected COM368 Reading phone info... Model: SM-J330F AP version: J330FXWU3BRK3 CSC version: J330FOJV3BRK3 CP version: J330FXXU3BRI3 Product code: XSG Phone SN: R58K55KM66V IMEI: 358494090623953 IMEI2: 358495090623950 Unique number: CQE000FF8F2E625 Reading IMEI... OK IMEI: 358494090623953 (SIGN: UNKNOWN) IMEI 2: 358495090623950 (SIGN: UNKNOWN) Done with Samsung Tool PRO v.36.2 BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. BE CAREFULL! IF YOU GET KNOX WARRANTY VOID STATUS DURING ROOT OR ANY OTHER PROCEDURE, THEN YOU WILL NOT BE ABLE UNLOCK THIS PHONE IN FUTURE! 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. Read certificate operation: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't use this function. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read CERT' button to read certificates. Operation: Read EFS Selected model: SM-J330F Software version: 36.2 Waiting ADB device... OK Reading phone info... Model: SM-J330F Android version: 8.0.0 PDA version: J330FXWU3BRK3 CSC version: J330FOJV3BRK3 Phone version: J330FXXU3BRI3 Product code: SM-J330FZDDXSG CSC country code: UAE CSC sales code: XSG Phone SN: R58K55KM66V IMEI: 358494090623953 HW version: MP 0.500 RF cal date: 20180529 Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2018-11-01 Boot Warranty bit: 0 Checking Super user right... true Reading EFS from phone... OK Saved to D:\BST\SamsungToolPRO\backup\EFS\EFS_SM-J330F_J330FXWU3BRK3_358494090623953_R58K55KM66V_9-6-2019_22-0-31.tar Done with Samsung Tool PRO v.36.2 |
