Old 08-03-2017, 22:07   #1 (permalink)
Member: 2502646
Sonork: 100.1581304
Thanks Meter: 17
j530f 2017 unlock error need modem file
Operation: Unlock
Selected model: SM-J530F
Software version: 29.0
Waiting ADB device... OK
Reading phone info...
Model: SM-J530F
Android version: 7.0
Product code: SM-J530FZDABTU
Phone version: J530FXXU1AQED
PDA version: J530FXXU1AQED
CSC version: J530FBTU1AQED
CSC country code: UK & IRE
CSC sales code: BTU
HW version: MP 0.500
Phone SN: RF8J62TMG6E
Chip name: EXYNOS7870
Modem board: SHANNON315
Security patch: 2017-05-01
RF cal date: 20170626
IMEI:
Checking Super user right... true
Reading NV data... OK
Checking NV data... OK
Reading data... OK
Detecting MODEM... OK
Reading MODEM... OK
Calculating... OK
Writing zTool... OK
Initialization zTool... OK
Running zTool, please wait...
Start... OK
Initialization... OK
Generate and check client proof... OK
Verify proof by client... OK
Reading data... error (1 19)
Start... OK
Reading data from phone... error (0)
Try downgrade modem if possible
Done with Samsung Tool PRO v.29.0
Old 08-04-2017, 06:12   #2 (permalink)
Member: 1855021
Sonork: 100.1619767
Thanks Meter: 7
Up up this thread...........
The Following User Says Thank You to KIMBRIAN20 For This Useful Post:
Old 08-04-2017, 06:23   #3 (permalink)
Member: 1659385
Sonork: 100.1678591
Thanks Meter: 105
Did you check the download tab in Z3X? Try modem from combination file in the download tab maybe it will work.
The Following User Says Thank You to jcdes For This Useful Post:
Old 08-04-2017, 09:11   #4 (permalink)
Member: 709142
Sonork: 100.114099
Thanks Meter: 11
Wink test by my
Model: SM-J530F
Product code: SM-J530FZDAXEF
Phone version: J530FXXU1AQF5
PDA version: J530FXXU1AQF5
CSC version: J530FXEF1AQE2
CSC country code: France
CSC sales code: XEF
Phone SN: RF8J70CZ4RL
Security patch: 2017-06-01
RF cal date: 20170705
IMEI:
Reading data... OK
Reading MODEM... OK
Calculating... OK
Writing zTool... OK
Start... OK
Reading data... OK
HWID: C4 DD 66 02 E8 D2 71 92 12 6E 40 59 40 26 57 3E
Calculating... OK
Unlocking... OK
Writing NV data... OK
Rebooting phone... OK
Unlock done
The Following User Says Thank You to EUROTELTEAM For This Useful Post:
Old 08-04-2017, 09:30   #5 (permalink)
Member: 399781
Thanks Meter: 48
just retry unlocking against should unlock
The Following User Says Thank You to riznix For This Useful Post:
Old 08-05-2017, 11:08   #6 (permalink)
Member: 1263334
Sonork: 100.1651849
Thanks Meter: 23
I need root
Hello br how to root phone pls kindly Reply willing to donate thanks.
The Following User Says Thank You to Nutty70 For This Useful Post:
Old 08-05-2017, 11:15   #7 (permalink)
Member: 2502646
Sonork: 100.1581304
Thanks Meter: 17
Originally Posted by jcdes View Post
did you check the download tab in z3x? Try modem from combination file in the download tab maybe it will work.
just try combination didnt unlock and also it needed rootwith does not work with combo file so the best bet is modem file or server upgrade pls dont try combo for unlock it a waste of m and time
The Following User Says Thank You to hamat For This Useful Post:
Old 08-05-2017, 11:33   #8 (permalink)
Member: 2502646
Sonork: 100.1581304
Thanks Meter: 17
u can get the root file from z3x box support the root is the last file on j530f firmware list
Old 08-06-2017, 05:06   #9 (permalink)
Member: 1855021
Sonork: 100.1619767
Thanks Meter: 7
Operation: Unlock
Model: SM-J530F
CSC sales code: BTU
IMEI:
Reading data... OK
Reading MODEM... OK
Calculating... OK
Writing zTool... OK
Start... OK
Start... OK
NEED MODEM DOWNGRADE PLSS.
Old 08-06-2017, 05:17   #10 (permalink)
Member: 1817604
Thanks Meter: 6
Try this at your own risk bro
1.downgrade
2.flash root
3.unlock
4.flash upgrade file
if worked just hite on thanks good luck
The Following User Says Thank You to norbertteco For This Useful Post:
Old 08-07-2017, 08:19   #11 (permalink)
sirnavid2010's Avatar
Member: 777729
Sonork: 100.1616470
Thanks Meter: 807
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock' for direct unlock.
Operation: Unlock
Please, allow USB debugging on phone... OK
Model: SM-J530F
Product code: SM-J530FZKDDBT
CSC version: J530FDBT1AQE9
CSC country code: Germany
CSC sales code: DBT
Phone SN: RF8J60LTGMT
RF cal date: 20170607
IMEI:
Reading data... OK
Reading MODEM... OK
Calculating... OK
Writing zTool... OK
Start... OK
Start... OK
The Following User Says Thank You to sirnavid2010 For This Useful Post:
Old 08-07-2017, 09:10   #12 (permalink)
Member: 777729
Sonork: 100.1616470
Thanks Meter: 807
1.downgrade
2.flash root
3.unlock
downgrade which ver ....any one unlock it?
UNLOCK INSTRUCTIONS:
To unlock:
Operation: Unlock
Model: SM-J530F
Product code: SM-J530FZKDO2U
CSC version: J530FO2U1AQF6
CSC sales code: O2U
IMEI:
Reading data... OK
Reading MODEM... OK
Calculating... OK
Writing zTool... OK
Start... OK
Start... OK
Old 08-07-2017, 10:25   #13 (permalink)
Member: 777729
Sonork: 100.1616470
Thanks Meter: 807
To unlock:
Operation: Unlock
Model: SM-J530F
Product code: SM-J530FZKDMSR
CSC version: J530FMSR1AQE9
CSC country code: Serbia
CSC sales code: MSR
IMEI:
Reading data... OK
Reading MODEM... OK
Calculating... OK
Writing zTool... OK
Start... OK
Start... OK
Old 08-07-2017, 14:04   #14 (permalink)
Member: 777729
Sonork: 100.1616470
Thanks Meter: 807
Originally Posted by EUROTELTEAM View Post
Model: SM-J530F
CSC sales code: XEF
IMEI:
Reading data... OK
Reading MODEM... OK
Calculating... OK
Writing zTool... OK
Start... OK
Reading data... OK
Calculating... OK
Unlocking... OK
Unlock done
use same firmware version and country and root but fail unlock...........!!!!!!!!!
To unlock:
Operation: Unlock
Model: SM-J530F
Product code: SM-J530FZKDXEF
CSC sales code: XEF
IMEI:
Reading data... OK
Reading MODEM... OK
Calculating... error (0 6)
Start... OK
Old 08-10-2017, 14:53   #15 (permalink)
Member: 506894
Sonork: 100.1667495
Thanks Meter: 28
tested from me
after root
flash modem only from combination file and unlock done
Model: SM-J530F
Phone version: J530FXXU1AQE5
CSC sales code: BTU
Phone SN: RF8J703VDWP
RF cal date: 20170703
IMEI:
Reading data... OK
Reading MODEM... OK
Calculating... OK
Writing zTool... OK
Start... OK
Reading data... OK
HWID: BB 3C 9F 3E 20 F4 15 35 59 78 F3 B6 CE E9 31 C9
Calculating... OK
Unlocking... OK
Unlock done
The Following User Says Thank You to eslamtaha For This Useful Post:
Page generated in 0.45165 seconds with 7 queries
