09-04-2019, 02:39 | #1 (permalink) |
No Life Poster Join Date: Jul 2012 Location: tunisia
Member: 1788877 Status: Offline Thanks Meter: 482 | J530F cert patched ... not registred on network How to fix that please Here is log REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. Operation: Patch Certificate Selected model: SM-J530F Software version: 36.8 Waiting ADB device... OK Reading phone info... Model: SM-J530F Android version: 8.1.0 PDA version: J530FXXU4BSC2 CSC version: J530FOXA4BSC2 Phone version: J530FXXU4BSC2 Product code: CSC country code: France CSC sales code: XEF Phone SN: IMEI: 355746092830107 HW version: RF cal date: Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2019-03-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Initialization data... OK Writing zTool... OK Initialization zTool... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.36.8 |
