02-04-2018, 10:13 | #76 (permalink) |
Freak Poster Join Date: May 2017 Location: Ghazni city-Afghanistan
Member: 2717040 Status: Offline Thanks Meter: 32 | info: Waiting ADB device... OK Reading phone info... Model: SM-G610F Android version: 6.0.1 Product code: Phone version: PDA version: G610FDDU1AQG2 CSC version: G610FOJV1AQG2 CSC country code: IRAN CSC sales code: THR HW version: Phone SN: R28J12375WH Chip name: EXYNOS7870 Modem board: Security patch: 2017-07-01 RF cal date: IMEI: Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.30.5 |
02-04-2018, 10:19 | #77 (permalink) | |
Member: 2717040 Status: Offline Thanks Meter: 32 | Quote:
this file good worling in v6.0.1 info: Waiting ADB device... OK Reading phone info... Model: SM-G610F Android version: 6.0.1 Product code: Phone version: PDA version: G610FDDU1AQG2 CSC version: G610FOJV1AQG2 CSC country code: IRAN CSC sales code: THR HW version: Phone SN: R28J12375WH Chip name: EXYNOS7870 Modem board: Security patch: 2017-07-01 RF cal date: IMEI: Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.30.5 | |
The Following User Says Thank You to Reha GSM For This Useful Post: |
02-15-2018, 14:01 | #78 (permalink) |
Major Poster Join Date: Nov 2016 Location: khordha odisha india
Member: 2652079 Status: Offline Thanks Meter: 10 | G 610F Adb Enable Without combination https://www.youtube.com/watch?v=bIEMgrNXBAs |
02-19-2018, 04:36 | #79 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Sri lanka Age: 43
Member: 454011 Status: Offline Sonork: 1656095 Thanks Meter: 147 | Samsung j7 prime G610f frp Done by Z3x Samsung j7 prime G610f frp Done by Z3x withuot combination https://forum.gsmhosting.com/vbb/****************************/file/jybgoxbl0g95wx2/frp.apk frp.apk file use with otg cable then select on ES file explorer sumeera suraj |
02-27-2018, 17:30 | #82 (permalink) | |
Freak Poster Join Date: Apr 2005 Location: Indonesia-Banjarmasin Age: 44
Member: 141854 Status: Offline Thanks Meter: 19 | Quote:
i try load to BL in odin write succes but my phone is error try again to AP in odin succes to,but my phone stil error i cant reset my frp | |
04-07-2018, 12:50 | #86 (permalink) |
Insane Poster Join Date: Mar 2015
Member: 2363135 Status: Offline Thanks Meter: 11 | FRP DONE Waiting ADB device... OK Reading phone info... Model: SM-G610F Android version: 6.0.1 Product code: SM-G610FZKGXSG Phone version: G610FDDU1API9 PDA version: G610FDDU1APLB CSC version: G610FOJV1APJ1 CSC country code: UAE CSC sales code: XSG HW version: MP 0.400 Phone SN: Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2016-10-01 RF cal date: IMEI: Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.30.9 |
04-13-2018, 21:48 | #87 (permalink) |
Crazy Poster Join Date: May 2017 Location: delhi Age: 27
Member: 2718706 Status: Offline Thanks Meter: 10 | g610f after flash combine file error flashing with official firmware FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-G610F Software version: 31.3 File analysis... OK Total file size: 0xF0C01801 (3852 Mb) Searching USB Flash interface... COM47 detected Setup connection... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending param.bin... error timeout Done with Samsung Tool PRO v.31.3 |
04-13-2018, 21:50 | #88 (permalink) |
Member: 2718706 Status: Offline Thanks Meter: 10 | g610f after flash combine file error flashing with official firmware FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-G610F Software version: 31.3 File analysis... OK Total file size: 0xF0C01801 (3852 Mb) Searching USB Flash interface... COM47 detected Setup connection... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending param.bin... error timeout Done with Samsung Tool PRO v.31.3 phone not return to normal mode please help meee |
06-08-2018, 09:23 | #90 (permalink) |
No Life Poster Join Date: May 2013 Location: Far From Home..:(
Member: 1948608 Status: Offline Thanks Meter: 1,744 | now a days it is simple to remove FRP...! do not flash any boot file without compare wit Device resent BINARY...!easy ways is let device to recovery, nd check device original BINARY,now download Combination from Z3X support, or google Same Binary, nd flash only Boot/sboot, or flash whole Combination... after Done FRP replace Boot/Sboot from Stock firmware....DONE |
