11-15-2016, 12:40 | #3 (permalink) | |
No Life Poster Join Date: May 2009 Location: Bangladesh Age: 30
Member: 1034743 Status: Offline Sonork: 100.1619212 Thanks Meter: 193 | Quote: SHOW SCREEN SW REV. CHECK FAIL. DEICE: 3, BINARY:1 Last edited by shaongsm; 11-15-2016 at 12:49. | |
11-15-2016, 12:55 | #4 (permalink) |
No Life Poster Join Date: Sep 2015 Location: Everywhere Age: 29
Member: 2454192 Status: Offline Sonork: 100.1674433 Thanks Meter: 693 | try realterm method 1.Download and installRealTerm program 2.Download and copy com.rootjunky.frpbypass-1.0.apk to the device micro sdcard or download once into the device. 3.Start phone and connect to WIFI also plug into the computer with your usb cable. 4.Start RealTerm on your pc and under pisplay check the box HALF DUPLEX 5.Right click on my computer and select manage once it opens click device manager then modems 6.Under modems you should see a Samsung device. right click it then select properties 7.Once the properties window opens select modem tab and see what port it is on like com5 for an example 8.Now that you know the com port number close all device manager windows and open RealTerm again 9.Under the ports tab in RealTerm enter your port number then click change. 10.Next, click the send tab. you will need to send these two commands with the Send ASCII button 11.First at+creg?\r\n 12.Then atd1234;\r\n 13.Look at your phone and the dailer will pop up 14.click on massege then write Google in sms |
11-15-2016, 14:23 | #7 (permalink) |
Member: 1034743 Status: Offline Sonork: 100.1619212 Thanks Meter: 193 | not work ,, 1st ok,, 2nd ,, error show log at+creg? at+creg? +CREG: 0,3 OK atd1234; atd1234; CLIR:255 OK ERROR atd0317841234; atd0317841234; CLIR:255 OK ERROR |
11-15-2016, 15:12 | #8 (permalink) | |
Freak Poster Join Date: Jun 2012 Location: Ethiopia || united State
Member: 1770631 Status: Offline Sonork: id Thanks Meter: 89 | Quote:
