12-29-2016, 08:16 | #1 (permalink) |
Freak Poster Join Date: Aug 2008 Location: kenya
Member: 839673 Status: Offline Sonork: pastorshaggy Thanks Meter: 66 | J700f 6.01 frp still on after reset Operation: Reset FRP/React/EE Selected model: SM-J700F Software version: 27.6 Searching Samsung USB Flash interface... COM49 detected Setup connection... Ok Reading PIT from phone... Ok Searching FRP lock... Ok Erasing FRP lock... Ok Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.27.6 any solution |
12-29-2016, 18:24 | #3 (permalink) |
Freak Poster Join Date: May 2005
Member: 149004 Status: Offline Thanks Meter: 14 | Try to downgrade the phone to the lowest fw, you can find it to Samobile, select your country and download it, flash the phone and do reset frp, it worked for me with other box, i'm new Z3X user but normally in the older fw version, you will find a low level protection, i hope that help you. Just one question after you make sam things with Z3X, it write all the time DONE WITH SAMSUNG TOOL PRO V27.6 ? Because i don't get that at the end of procedure. Regards. Ice. |
12-30-2016, 03:19 | #6 (permalink) |
Freak Poster Join Date: Sep 2016 Location: uknow
Member: 2630755 Status: Offline Thanks Meter: 63 | You try this firmware https://www.**************/firmwares...FODD2APD4_SLK/ |
12-30-2016, 06:33 | #7 (permalink) |
Member: 839673 Status: Offline Sonork: pastorshaggy Thanks Meter: 66 | link not working even after downloading firmware from site error in flashing 6.01 peration: Flash Selected model: SM-J700F Software version: 27.6 File analysis... Ok Total file size: 0x7E234D40 (2018 Mb) Searching USB Flash interface... COM49 detected Setup connection... Ok Reading PIT from phone... Ok Sending sboot.bin... Ok Sending cm.bin... error timeout It looks like you have an unsucessful operation, try this link for solution - Done with Samsung Tool PRO v.27.6 |
12-30-2016, 06:53 | #8 (permalink) |
Member: 839673 Status: Offline Sonork: pastorshaggy Thanks Meter: 66 | still facing face problem in new update frp still on Operation: Reset FRP/React/EE Selected model: SM-J700F Software version: 27.7 Searching Samsung USB Flash interface... COM49 detected Setup connection... Ok Reading PIT from phone... Ok Searching FRP lock... Ok Erasing FRP lock... Ok Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.27.7 |
12-30-2016, 08:33 | #9 (permalink) |
Freak Poster Join Date: Jul 2014 Location: nepal
Member: 2226403 Status: Offline Thanks Meter: 32 | latest new frp reset method no need device only tow sim solved this may help you https://goo.gl/BiqZrW |
12-30-2016, 11:09 | #10 (permalink) | |
Member: 839673 Status: Offline Sonork: pastorshaggy Thanks Meter: 66 | [ Quote:
still not working on 6.01 j7000f frp remove still on frp | |
01-15-2017, 14:09 | #11 (permalink) |
No Life Poster Join Date: Nov 2014 Location: BADARPUR ASSAM (I N D I A) Age: 34
Member: 2298142 Status: Offline Thanks Meter: 240 | FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-J700F Software version: 27.7 File analysis... Ok Total file size: 0x7EE11B40 (2030 Mb) Searching USB Flash interface... COM21 detected Setup connection... Ok Reading PIT from phone... Ok Sending sboot.bin... Ok Sending cm.bin... error timeout It looks like you have an unsucessful operation, try this link for solution - inurl:f453 site:http://forum.gsmhosting.com/ "Selected model: SM-J700F" "Sending cm.bin error timeout" - Пошук Google Done with Samsung Tool PRO v.27.7 |
01-15-2017, 18:27 | #12 (permalink) |
No Life Poster Join Date: May 2016
Member: 2577670 Status: Offline Thanks Meter: 883 | This method worked for me: http://forum.gsmhosting.com/vbb/f453...moval-2180813/ DO NOT FORGET TO CLICK ON THE THANKS BUTTON |
