11-10-2016, 08:11 | #1 (permalink) |
Insane Poster Join Date: Apr 2016
Member: 2566585 Status: Offline Sonork: 100.1673331 Thanks Meter: 5 | j700f frp lock error my j700f frimwaer version. (J700FXXU3BPJ1_J700FOJK3BPJ1_ILO) letest. i try all combination file from z3x server but not work on this version . if any budy solve this problam plz shaer. Operation: Reset FRP/React/EE Selected model: SM-J700F Software version: 27.1 Searching Samsung USB Flash interface... COM4 detected Setup connection... ok Reading PIT from phone... ok Searching FRP lock... ok Erasing FRP... ok Searching Reactivation lock... not supported Searching EE lock... ok Erasing EE lock... error Done with Samsung Tool PRO v.27.1 |
11-10-2016, 08:43 | #4 (permalink) |
No Life Poster Join Date: Sep 2015 Location: Everywhere Age: 29
Member: 2454192 Status: Offline Sonork: 100.1674433 Thanks Meter: 693 | J700F_FRP_Reset_Pack.tar flash this sboot and try again |
11-10-2016, 09:00 | #5 (permalink) | |
Member: 2566585 Status: Offline Sonork: 100.1673331 Thanks Meter: 5 | Quote:
11-10-2016, 09:24 | #8 (permalink) |
Member: 2454192 Status: Offline Sonork: 100.1674433 Thanks Meter: 693 | write on google "real term" download this software and try this method 1.Download and installRealTerm program 2.Download and copy com.rootjunky.frpbypass-1.0.apk to the device micro sdcard or download once into the device. 3.Start phone and connect to WIFI also plug into the computer with your usb cable. 4.Start RealTerm on your pc and under pisplay check the box HALF DUPLEX 5.Right click on my computer and select manage once it opens click device manager then modems 6.Under modems you should see a Samsung device. right click it then select properties 7.Once the properties window opens select modem tab and see what port it is on like com5 for an example 8.Now that you know the com port number close all device manager windows and open RealTerm again 9.Under the ports tab in RealTerm enter your port number then click change. 10.Next, click the send tab. you will need to send these two commands with the Send ASCII button 11.First at+creg?\r\n 12.Then atd1234;\r\n 13.Look at your phone and the dailer will pop up 14.click on massege then write google.com in sms |
11-10-2016, 10:12 | #10 (permalink) | |
First at+creg?\r\n ok but 2nd atd1234; CLIR:255 atd1234; OK ERROR | |
11-10-2016, 11:03 | #13 (permalink) |
Member: 2454192 Status: Offline Sonork: 100.1674433 Thanks Meter: 693 | https://forum.gsmhosting.com/vbb/****************************/?7m3xu8p89gej8qy try this tool it will work |
11-10-2016, 11:06 | #14 (permalink) | |
