01-22-2016, 05:19 | #6 (permalink) | |
Freak Poster Join Date: Dec 2007 Location: India, Haldwani Age: 38
Member: 650289 Status: Offline Thanks Meter: 56 | Quote:
but in j2 / j5 i tried frp reset with z3x says failed but when i tried after flesh frp reset done in seconds . | |
02-13-2016, 17:06 | #9 (permalink) |
No Life Poster Join Date: Apr 2010 Location: United Arab Emirates ( DUBAI )
Member: 1294044 Status: Offline Thanks Meter: 1,269 | |
03-22-2016, 08:33 | #10 (permalink) |
No Life Poster Join Date: Nov 2014 Location: BADARPUR ASSAM (I N D I A) Age: 34
Member: 2298142 Status: Offline Thanks Meter: 240 | j700f FRP not done any solutions....................., UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-J700F Software version: 24.7 Searching Samsung USB Flash Interface... detected COM33 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... error Done with Samsung Tool PRO v.24.7 |
