11-24-2015, 15:16 | #1 (permalink) |
No Life Poster Join Date: Aug 2010 Location: SearchinG ... Age: 39
Member: 1369772 Status: Offline Thanks Meter: 297 | J700H after write CERT file - Emergency call only BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. 7. Press 'Write NV DATA' if you need to restore NV backup. Operation: Write CERT Selected model: SM-J700H/DS Software version: 23.4 Checking certificate file... OK KEY ID: 0949 Waiting ADB device... OK Reading phone info... Model: SM-J700H Android version: 5.1.1 Product code: SM-J700HZDDBNG Phone version: J700HXXU1AOG2 PDA version: J700HXXU1AOG5 CSC version: J700HODD1AOG2 CSC country code: Bangladesh CSC sales code: BNG HW version: MP 0.400 Phone S/N: 00000000000 Modem board: SHANNON310 RF cal date: 20150831 IMEI: Checking Super user right... true Reading nv data... OK Writing nv data... OK Rebooting phone... OK Write CERT done Done with Samsung Tool PRO v.23.4 |
04-08-2016, 10:21 | #5 (permalink) | |
Freak Poster Join Date: Jul 2012 Location: Karachi, Pakistan Age: 28
Member: 1785307 Status: Offline Thanks Meter: 112 | Quote:
SM-J700F__R28G822BS6P_12-9-2015_12-22-2 - Download - 4shared First Backup QCN, Write Cert Above at last write QCN File | |
12-11-2016, 13:43 | #6 (permalink) | |
Banned Join Date: Jul 2006 Location: dword ptr [ebp-1C], edx
Member: 322417 Status: Offline Thanks Meter: 940 | Quote:
j700f has 0949 key j700h has 0901 key they are different , Dude even without bad intention you can damage other member phones | |
The Following 2 Users Say Thank You to Formingus For This Useful Post: |
