02-15-2016, 07:04 | #1 (permalink) |
Freak Poster Join Date: Jun 2013 Location: philippines
Member: 1954433 Status: Offline Thanks Meter: 27 | j700h/ds frp reset.. Operation: Reset FRP/React/EE Selected model: SM-J700H/DS Software version: 24.2 Searching Samsung USB Flash Interface... detected COM26 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... error Done with Samsung Tool PRO v.24.2 or this model is not supported for frp reset,,i tried the v23.3 logs said frp reset done but phone still stuck on frp |
02-15-2016, 09:56 | #4 (permalink) |
Freak Poster Join Date: May 2010 Location: Egypt Age: 33
Member: 1298419 Status: Offline Sonork: 100.1672105 Thanks Meter: 69 | Downgrade sboot to older firmware with the same RP. Then Wipe cache partition. Do reset operation again. |
The Following User Says Thank You to expenaticx For This Useful Post: |
02-15-2016, 18:58 | #5 (permalink) | |
No Life Poster Join Date: Nov 2014 Location: Pakistan/UAE/WorldWide Age: 26
Member: 2302076 Status: Offline Sonork: 100.1663298 Thanks Meter: 185 | Quote:
Can you please give me link for this sboot because i am afraid that many people dead their phone by flashing fimrware on frp lock on please guide me which firmware was suitable to it or which sboot ??? Br Shahzaib Jahangir | |
The Following User Says Thank You to shahsoft For This Useful Post: |
02-15-2016, 22:22 | #6 (permalink) |
Member: 1298419 Status: Offline Sonork: 100.1672105 Thanks Meter: 69 | Your phone will not die if you flash sboot (Bootloader) with the same RP(ROLLBACK PROTECTION) as the current firmware already in the phone. So: 1.Detect the phone android version from recovery mode (Ex:J700HXXU1APA3). 2.Download full firmware or just Bootloader with the same RP and older date release (Ex:J700HXXU1AOI6). 3.Flash via Odin in download mode. |
The Following 5 Users Say Thank You to expenaticx For This Useful Post: |
02-16-2016, 00:08 | #7 (permalink) | |
Thank you very much sir You give me very good information Br Shahzaib Jahangir | |
02-17-2016, 06:01 | #8 (permalink) |
Member: 1954433 Status: Offline Thanks Meter: 27 | thread update...j700h/ds frp remove by flashing the phone first then do reset frp. but still waiting for z3x team to support frp reset without flashing..goodluck team |
The Following User Says Thank You to cndk2_32 For This Useful Post: |
02-17-2016, 11:09 | #9 (permalink) | |
Freak Poster Join Date: Oct 2012 Location: Viet Nam (VFS)
Member: 1822938 Status: Offline Sonork: 100.1656339 Thanks Meter: 63 | Quote:
just done with g920s | |
02-17-2016, 12:03 | #10 (permalink) | |
Freak Poster Join Date: Oct 2014 Location: Tokyo
Member: 2266922 Status: Offline Sonork: 100.1659771 Thanks Meter: 64 | Quote:
02-17-2016, 13:14 | #11 (permalink) |
Member: 1298419 Status: Offline Sonork: 100.1672105 Thanks Meter: 69 | Rollback Protection is bit in the firmware , that prevent flashing firmware with lower RP bit than the one currently on the phone (prevent Downgrade). You can only flash firmware with the same RP bit as currently phone firmware or higher. Example: N910TUVU2DOK2 N910TUVU1COG2 N910TUVU1COD6 You Can flash OG2 Firmware to phone which currently have OG2 or OD6 not OK2. You Can flash OD6 Firmware to phone which currently have OG2 or OD6 not OK2. You Can flash OK2 Firmware to phone which currently have OK2 or OG2 or OD6. |
The Following 4 Users Say Thank You to expenaticx For This Useful Post: |
02-20-2016, 23:33 | #12 (permalink) | |
my phone dead and i was use jtag to revive it bro .. | |
02-21-2016, 08:50 | #14 (permalink) |
No Life Poster Join Date: Feb 2015 Location: Ph
Member: 2348059 Status: Offline Sonork: 100.293844 Thanks Meter: 45 | help this try Searching Samsung USB Flash Interface... detected COM5 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... error Done with Samsung Tool PRO v.24.1 Detecting phone, wait.. Detected: Modem (COM5) Bypassing data, wait.... Bypass ok. Reading Data,wait.... Done Chipset: LSI7580 Data Found, processing... Resetting FRP, wait.. FRP OFF... Done Now you can wipe phone to remove remaining data... Restarting Phone Restart Ok All Done Done. all not help |
08-11-2016, 09:52 | #15 (permalink) | |
Freak Poster Join Date: Apr 2005 Location: india Age: 40
Member: 135518 Status: Offline Sonork: 1605927:cellcomna Thanks Meter: 56 | Quote:
