03-29-2016, 11:56 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: Bangladesh/USA/UK Age: 39
Member: 1033714 Status: Offline Sonork: 1640811:mothertelecom Thanks Meter: 91 | j700h Reactivation lock... not supported Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-J700H/DS Software version: 25.0 Searching Samsung USB Flash Interface... detected COM20 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... error Done with Samsung Tool PRO v.25.0 help how to reset |
03-30-2016, 12:05 | #2 (permalink) |
Major Poster Join Date: Aug 2009
Member: 1091149 Status: Offline Thanks Meter: 2 | j700h google lock same hear Searching Samsung USB Flash Interface... detected COM20 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... error |
