01-11-2018, 14:54 | #1 (permalink) |
No Life Poster Join Date: Aug 2004 Age: 44
Member: 77218 Status: Offline Thanks Meter: 88 | j700t 7.1.1 ok with z3x Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. To read security codes: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To read security codes via diagnostic port: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes DIAG' button to read security codes. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Read Codes DIAG Selected model: SM-J700T Software version: 30.4 Checking hash file... OK Searching Samsung modem... detected COM121 Reading phone info... OK Model: SM-J700T AP version: J700TUVU3BQK3 CSC version: J700TTMB3BQK3 CP version: J700TUVU3BQK3 Product code: TMB Phone SN: R58J513VAER Unique number: C0000C7804126A3 Searching Samsung diag port... detected COM120 Reading phone info... OK CP version: J700TUVU3BQK3 CP build: Nov 7 2017 16:51:13 Reading data from phone... OK Reading NV data... OK Modem board: SHANNON310 Checking NV data... OK Calculating... OK Please wait, calculating codes... OK (time - 00:00:03) Freeze code: 86941425 NET lock: 64603848 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.30.4 |
