Old 07-21-2016, 23:24   #16 (permalink)
Member: 398910
did anyone tried it on J700t model and it worked?
Old 07-22-2016, 02:31   #17 (permalink)
Member: 1202336
Sonork: 100.1609163
Thanks Meter: 21
not work, 700t and 700t1 same phones
Old 07-22-2016, 04:39   #18 (permalink)
markhaines1985's Avatar
Member: 2532914
Thanks Meter: 1,077
Did you flash the eng_sboot via z3x and not odin? Let me check the file also. I may have put the wrong file in the tar file.
The Following 3 Users Say Thank You to markhaines1985 For This Useful Post:
Old 07-22-2016, 17:28   #19 (permalink)
Member: 1185408
Sonork: 100.1668702
Thanks Meter: 17
friend please check the archives ...
not work
Old 07-23-2016, 18:53   #20 (permalink)
Member: 2156601
Thanks Meter: 3
correct those files do not work to reset j700t. Odin'd files and then I ran z3x 26.0 and no success
Old 07-23-2016, 21:56   #21 (permalink)
Member: 2539595
Sonork: 1000.2
Originally Posted by onaikel View Post
Operation: Reset FRP/React/EE
Selected model: SM-J700F
Software version: 25.7
Searching Samsung USB Flash Interface... detected COM10
Setup connection... OK
Reading PIT from phone... OK
Searching FRP lock... OK
Erasing FRP... error
Done with Samsung Tool PRO v.25.7
Old 07-23-2016, 22:06   #22 (permalink)
concepttheman's Avatar
Member: 1637281
Sonork: 100.1657188
Thanks Meter: 82
Root it and i can do it.
Old 07-24-2016, 00:31   #23 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 957
how to root with FRP on ?
Old 07-26-2016, 01:18   #24 (permalink)
Member: 2532914
Thanks Meter: 1,077
Here is how you remove FRP on J700T:
1. Put phone into download mode
2. Unzip Factory Binary File (Download Here)
3. Select AP tab in Odin and flash Factory Binary File.
4. When on Main screen click on menu button.
5. Click on settings.
6. Click on about phone
7. Tap on Build Number until it says "Developer Options Now Enabled".
8. Go back to Settings and click on Developer Options.
9. Turn on OEM Unlocking
10. Put phone into download mode.
11. Unzip Stock rom (Download Here)
12. Select AP tab in Odin and flash Stock Rom.
FRP REMOVED!!!
The Following 9 Users Say Thank You to markhaines1985 For This Useful Post:
Old 07-26-2016, 22:05   #25 (permalink)
Member: 1185408
Sonork: 100.1668702
Thanks Meter: 17
FRP REMOVED!!!
It has no option bro
OEM release
Old 07-28-2016, 14:19   #26 (permalink)
Member: 1637281
Sonork: 100.1657188
Thanks Meter: 82
Recovery...adb...bread crumbs for you
Old 07-28-2016, 18:34   #27 (permalink)
Member: 1185408
Sonork: 100.1668702
Thanks Meter: 17
Solution ready
good
Old 07-28-2016, 18:43   #28 (permalink)
Member: 2603722
Sonork: GSM BANGLADESH
Thanks Meter: 7
use miracle box for unlock frp............
Old 07-30-2016, 02:59   #29 (permalink)
jepetu's Avatar
Member: 181633
Thanks Meter: 543
OEM release
Think man, solution varies a llittle in order because in factory firmware there isn't an "OEM unlock" option, but you will got it with files posted by markhaines1985.
hint: you have to enable usb debug in stock flash.
The Following User Says Thank You to jepetu For This Useful Post:
Old 07-30-2016, 03:03   #30 (permalink)
jepetu's Avatar
Member: 181633
Thanks Meter: 543
By the way @markhaines1985
Do you have by chance the J700P factory binary for same purposes?
Thanks a lot for your wonderful contribution.
Page generated in 0.34414 seconds with 7 queries
