Old 07-30-2016, 13:43   #31 (permalink)
markhaines1985's Avatar
Member: 2532914
Thanks Meter: 1,063
Originally Posted by jepetu View Post
By the way @markhaines1985
Do you have by chance the J700P factory binary for same purposes?
Thanks a lot for your wonderful contribution.
Yes I do. Give me a little bit to upload it to my server.
The Following User Says Thank You to markhaines1985 For This Useful Post:
Old 07-30-2016, 13:53   #32 (permalink)
Member: 2532914
Thanks Meter: 1,063
Here is factory binary file for J700P
CLICK HERE TO DOWNLOAD
The Following 10 Users Say Thank You to markhaines1985 For This Useful Post:
Old 07-30-2016, 19:58   #33 (permalink)
jepetu's Avatar
Member: 181633
Thanks Meter: 536
Thanks a lot, another one bites the dust.... with same method.
The Following 2 Users Say Thank You to jepetu For This Useful Post:
Old 07-30-2016, 20:01   #34 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
Thanks Meter: 3,515
Hi, thanks for the file. Won't you have the factory and stock firmwares for G550T1?
Thanks in advance!
Old 07-30-2016, 21:23   #35 (permalink)
Member: 2176622
Thanks Meter: 5
I dont mean to sound like a dumb noob or anything, but I flashed the factory firmware, and enabled usb debugging and tried to load the stock firmware. The FRP lock is still there. I even tried doing a menu reset with factory firmware and that didn't work either. Are we missing a step? By the way thank you markhaines1985 I really appreciate all the help you've offered us
Old 07-30-2016, 22:29   #36 (permalink)
Member: 2532914
Thanks Meter: 1,063
Here is Factory Binary For G550T1 which works for both T-Mobile and MetroPCS variants.
CLICK HERE TO DOWNLOAD G550T1 FACTORY BINARY FILE
Here is stock rom for G550T1
CLICK HERE TO DOWNLOAD STOCK ROM G55OT1 PF1
Old 07-30-2016, 22:39   #37 (permalink)
Member: 2566911
Thanks Meter: 28
@markhaines1985
will j700t factory binary work on j700t1?
p.s do you have g530t or g530t1 factory binary?
Old 07-31-2016, 02:36   #38 (permalink)
Member: 2156601
Thanks Meter: 3
Think man, solution varies a llittle in order because in factory firmware there isn't an "OEM unlock" option, but you will got it with files posted by markhaines1985.
hint: you have to enable usb debug in stock flash.
I have usb debugging enabled and Im trying remove frp. How do I enable the option? Can you help thank you
Old 08-01-2016, 16:34   #39 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
Thanks Meter: 3,515
Thanks, it worked great!
Old 08-01-2016, 23:37   #40 (permalink)
Member: 2176622
Thanks Meter: 5
What are we supposed to do after we flash factory firmware to remove frp? Delete the partitions thru adb commands? No box supports this model yet unless an update JUST came out within the last two hours. Same with G550T1. I downloaded both firmwares, flashed factory firmare, and I'm stuck. Hard reset does not clear the FRP, neither does a menu factory reset. Do you guys know about something that I don't know?
Old 08-02-2016, 08:45   #41 (permalink)
Member: 2306078
Sonork: 1660961
Thanks Meter: 19
So the end , any solution for J700T FRP 6.0.1 , all Master ???
Thank you
Old 08-02-2016, 08:47   #42 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 928
Thank you
u have read page 2 #24 how to do remove frp?
Old 08-02-2016, 08:51   #43 (permalink)
Member: 1002905
Sonork: 100.1648296
Thanks Meter: 2
https://www.youtube.com/watch?v=6w2LW2mLnHw
Old 08-02-2016, 16:40   #44 (permalink)
Member: 455304
Thanks Meter: 306
have stock firmware for g550t ??
Old 08-02-2016, 21:28   #45 (permalink)
jepetu's Avatar
Member: 181633
Thanks Meter: 536
Try these links be carefull with the OPT file, it's the EFS:
https://idlekernel.com/flash-tools/f...U1APF1.tar.md5
Page generated in 0.37897 seconds with 7 queries
