Old 08-11-2016, 00:20   #61 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 928
Originally Posted by bawanyh View Post
adb shell content insert --uri content://settings/secure --bind name:s:user_setup_complete --bind value:s:1
i try too help some 1 with this commant on j700t1 via adb enable but he say nothing heppen so any 1 confirm work on j700T1?
Old 08-11-2016, 18:01   #62 (permalink)
Member: 1485924
Thanks Meter: 6
command not working frp still on
can anyone confirm this is the right command, frp still on
Old 08-11-2016, 22:07   #63 (permalink)
Member: 2431464
Talking Previous hint: enable usb debug in STOCK FW, use the factory fw and your mind to get
I have used my mind and a lot of hours lol i can not enable usb debugging in Stock FW, any other hint would be greatly appreciated.
Old 08-12-2016, 21:56   #64 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
Thanks Meter: 3,515
I can confirm that it works.
The Following 2 Users Say Thank You to y3kt For This Useful Post:
Old 08-15-2016, 01:26   #65 (permalink)
Member: 2327311
Thanks Meter: 5
hey y3kt, can you please share how exactly you did it, I've been trying the adb command since oem unlock is not there. But after I enter it nothing happens and frp on still shows in download mode.
Call me lazy all you (not you y3kt, speaking in general) want but not everyone is as smart as some of you guys or have enough experience as you might have.
Old 08-15-2016, 03:12   #66 (permalink)
Member: 2327311
Thanks Meter: 5
ok finally found a solution
1. Flash FACTORY_BINARY_J700T_PF2 wtih Odin
2. Flash ENG_SBOOT_J700T_1_PF2.tar
3. Flash STOCK_ROM_J700T_PD2 or any stock firmware
3. Extract boot.img from FACTORY_BINARY_J700T_PF2
4. Use 7zip to convert it into boot.img.tar then flash with odin
After phone rebooted has adb enabled and just ran these 3 commands in minimal adb and fastboot (to me works better than normal cmd your choice)
1- devices
2- shell netcfg
3- shell content insert --uri content://settings/secure --bind name:s:user_setup_complete --bind value:s:1
Pretty simple with the right files, I don't really know how or where to upload them, trust me not going thru 3 hours of search history to find links. Google the files same as I typed them in steps and should come up first.
I don't know if there's is a easier way, all it took me was about 10 mins, not counting all it took reading, trials, and finding the files.
Only tested this in J700T dont know if would work on T1 or F. Will try to put the files somewhere for you guys stuck can download.
The Following 5 Users Say Thank You to fullr3 For This Useful Post:
Old 08-16-2016, 02:37   #67 (permalink)
Member: 996077
Thanks Meter: 18
1- devices
2- shell netcfg
did this and the last 3 commands dont do anything and say not found.
Old 08-16-2016, 03:46   #68 (permalink)
concepttheman's Avatar
Member: 1637281
Sonork: 100.1657188
Thanks Meter: 80
You are right. Just get to busy to see updates
Originally Posted by markhaines1985 View Post
Why do you need root for G890A. Just unlock with new exynos unlock solution the write cert via modem. No root or engineer files necessary. All done with USB cable
Yeah. The new updates just reset the msl location after you unlock then right cert.
Old 08-16-2016, 03:49   #69 (permalink)
Member: 1637281
Sonork: 100.1657188
Thanks Meter: 80
Frp
1- devices
2- shell netcfg
The eng sboot is the key just be quick lol.
Old 08-17-2016, 01:45   #70 (permalink)
Member: 2425271
Thanks Meter: 4
@markhaines1985
Can You give me the J700H Eng sboot? Thanks
Old 08-17-2016, 19:48   #71 (permalink)
Member: 2077877
1- devices
2- shell netcfg
for anyone that was stuck on the part of the boot img unzip the factory binary then add .zip at the end of the file then go in and extrack only the boot file and there you have it had me thinking for a bit but finally figure it out
Old 08-17-2016, 20:18   #72 (permalink)
Member: 996077
Thanks Meter: 18
ok in my experience the ENG sboot wont stick on some phones.
you have to keep flashing it and flashing it until it finally sticks lol
just a heads up. as soon as you have ADB just run the command and it bypasses the setup
enable oem unlocking and hard reset and VOILA!
The Following User Says Thank You to BootyHunter57 For This Useful Post:
Old 08-17-2016, 21:13   #73 (permalink)
Member: 2077877
how you figure that the eng sboot wasn't sticking I get the adb and when I input the command it tells me the insert is not found
Old 08-17-2016, 21:47   #74 (permalink)
Member: 2077877
[email protected]:/ $ insert --uri content://settings/secure --bind name:s:user_se
s/secure --bind name:s:user_setup_complete --bind value:s:1 <
/system/bin/sh: insert: not found
127|[email protected]:/ $
Old 08-17-2016, 21:59   #75 (permalink)
Member: 2077877
nevermind I got it to work I just flashed regular sboot and then wrote the command and flawlessly worked
Page generated in 0.42195 seconds with 7 queries
