06-22-2017, 20:17 | #1 (permalink) |
No Life Poster Join Date: Nov 2005
Member: 199538 Status: Offline Thanks Meter: 54 | J700T1 j700t1uvu3aqc3 impossible FRP !!! hello support this version of J700T1 j700t1uvu3aqc3 .. is the last one... is impossible to make a downgrade to Any boot before... then always when Sboot eng and others be flashed the phone is in Restart Logo mode ... and i had to back to the original firmware j700t1uvu3aqc3 to revive the phone again... Any idea for FRP... remember.. any ENG boot available stuck the phone any idea support !!! |
06-22-2017, 21:33 | #2 (permalink) |
No Life Poster Join Date: Oct 2006
Member: 380870 Status: Offline Thanks Meter: 159 | Try like this SAMSUNG ALL MODEL AND SAMSUNG S8 S8+ ALL FRP REMOVE EASY WAY WITH FLASH METHOD STEP 1 FLASH WITH COMBINATION FILES STEP 2 FLASH WITH 4 FILES SELECT CSC AS HOME CSE FILE AFTER FLASH FRP WILL GONE THEN JUST HARD RESET YOU CAN REMOVE ALL FRP SAME METHOD READ CAREFULLY ALL Sent from my SM-G950F using Tapatalk |
The Following User Says Thank You to zoltar1308 For This Useful Post: |
06-22-2017, 22:15 | #4 (permalink) | |
Junior Member Join Date: May 2016
Member: 2580227 Status: Offline Thanks Meter: 0 | Quote:
Sent from my SM-G950F using Tapatalk | |
07-12-2017, 04:45 | #10 (permalink) | |
Freak Poster Join Date: Aug 2009 Location: NYC
Member: 1105429 Status: Offline Thanks Meter: 118 | Quote:
SELECT CSC AS HOME CSE FILE what do you mean by that? csc as HOME? do you mean flash the csc ? flash AP BL CP but NOT CSC? | |
07-12-2017, 06:06 | #11 (permalink) |
Member: 380870 Status: Offline Thanks Meter: 159 | Some firmware have 5 files. BL AP CP CSC AND HOME CSC. YOU hav to select in odin or z3x BL AP CP AND HOME CSC. THIS method is from hazbul Sent from my SM-G950F using Tapatalk |
07-12-2017, 06:11 | #12 (permalink) |
Member: 380870 Status: Offline Thanks Meter: 159 | Or try like this http://forum.gsmhosting.com/vbb/show...php?p=12240741 Sent from my SM-G950F using Tapatalk |
