02-28-2018, 03:55 | #1 (permalink) |
No Life Poster Join Date: Feb 2007
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | J700T1 MetroPC Unlock Code: UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. To read security codes: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To read security codes via diagnostic port: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes DIAG' button to read security codes. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Read Codes DIAG Selected model: SM-J700T1 Software version: 30.7 Please wait, generating hash codes file, this can take few minutes... OK Searching Samsung modem... detected COM214 Reading phone info... OK Model: SM-J700T1 AP version: J700T1UVU3BQK3 CSC version: J700T1TMK3BQK3 CP version: J700T1UVU3BQK3 Product code: TMK Phone SN: R58J2040JSK Unique number: C00004B738E5693 Searching Samsung diag port... detected COM215 Reading phone info... OK CP version: J700T1UVU3BQK3 CP build: Nov 7 2017 16:51:10 Reading data from phone... OK Reading NV data... OK Modem board: SHANNON310 Checking NV data... OK Calculating... OK Please wait, calculating codes... OK (time - 00:00:01) Freeze code: 46136816 NET lock: 79482964 SUB lock: 00000000 SP lock: 05841642 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.30.7 |
03-03-2018, 03:52 | #4 (permalink) |
Freak Poster Join Date: Jun 2016
Member: 2592628 Status: Offline Thanks Meter: 212 | no server click "unlock" not unlock via server. j727t1 is server. j700t1 is direct unlock, no server needed. only need root. cf auto root works fine, junk phone doesn't have NFC anyways so knox means nothing |
