02-22-2018, 17:09 | #1 (permalink) |
Junior Member Join Date: Nov 2014 Location: mumbai
Member: 2301792 Status: Offline Thanks Meter: 7 | j701f repair imei error Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. Operation: Repair Selected model: SM-J701F Software version: 30.8 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... OK Reading phone info... Model: SM-J701F Android version: 7.0 Product code: SM-J701FZKDINS Phone version: J701FXXU3ARA6 PDA version: J701FDDU3ARB1 CSC version: J701FODD3ARB1 CSC country code: India CSC sales code: INS HW version: MP 0.400 Phone SN: RZ8JB1AME6Y Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2018-02-01 RF cal date: 20171120 IMEI: 35363209xxxxxxx Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... error (0) Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... error (1 19) Done with Samsung Tool PRO v.30.8 |
