01-03-2017, 10:49 | #1 (permalink) |
No Life Poster Join Date: Apr 2016
Member: 2561651 Status: Offline Sonork: 100.******* Thanks Meter: 292 | j7108 FRP not remove i tried its showing PASS but its stuck Operation: Reset FRP/React/EE Selected model: SM-J7108 Software version: 27.7 Searching Samsung USB Flash interface... COM9 detected Setup connection... Ok Reading PIT from phone... Ok Searching FRP lock... Ok Erasing FRP lock... Ok Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.27.7 |
02-01-2017, 13:16 | #10 (permalink) |
Insane Poster Join Date: Sep 2008
Member: 853976 Status: Offline Thanks Meter: 23 | First Flash with J7108ZMU1APC3_J7108CHM1APC3 you can download in Z3X To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. |
02-02-2017, 09:31 | #12 (permalink) | |
Freak Poster Join Date: Sep 2015
Member: 2453779 Status: Offline Thanks Meter: 75 | Quote:
02-05-2017, 13:28 | #15 (permalink) |
Member: 2561651 Status: Offline Sonork: 100.******* Thanks Meter: 292 | brother kindly read and focus the words and problem your set is in custom binray block ? so its need to flash stock ?ok i,m i right? now you need the latest or correct binray for that, and that,s it after you should in ON mode after that you can reset it via z3x or octo and if you not have both so try with real tream thats it and if you still cant unterstand so come to teamvewier i,ll remotly fix for you in free but you should fix with mine way |
