05-01-2017, 17:35 | #4 (permalink) |
Crazy Poster Join Date: Jun 2013
Member: 1954652 Status: Offline Thanks Meter: 11 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Write CERT' to restore certificates. 7. Press 'Write NV DATA' if you need to restore NV backup. Read certificate operation: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read CERT' button to read certificates. (Note, that the cert file for this model is unique. You can write cert, wich is readed from this device exactly.) Operation: Write CERT Selected model: SM-J710F Software version: 28.1 Waiting ADB device... Ok Reading phone info... Model: SM-J710F Android version: 6.0.1 Product code: Phone version: J710FXXU2AQB2 PDA version: J710FXXU2AQB3 CSC version: J710FOJV2AQB2 CSC country code: UAE CSC sales code: XSG HW version: Phone SN: Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-02-01 RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Reading data... Ok Detecting MODEM... Ok Reading MODEM... Ok Calculating... Ok Writing zTool... Ok Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data... error (1 19) Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data from phone... error (0) Try downgrade modem if possible Done with Samsung Tool PRO v.28.1 |
05-01-2017, 17:36 | #5 (permalink) |
Member: 1954652 Status: Offline Thanks Meter: 11 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 8. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Repair Selected model: SM-J710F Software version: 28.1 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... Ok Reading phone info... Model: SM-J710F Android version: 6.0.1 Product code: Phone version: PDA version: J710FXXU2AQB3 CSC version: J710FOJV2AQB2 CSC country code: UAE CSC sales code: XSG HW version: Phone SN: Chip name: EXYNOS7870 Modem board: Security patch: 2017-02-01 RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Can not detected modem type Done with Samsung Tool PRO v.28.1 |
05-01-2017, 17:42 | #6 (permalink) |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,557 | phone modem not work. you have to fix modem 1st and the you can do any job related to repair imei. you can try flash phone. just use search button. |
