11-03-2016, 10:30 | #1 (permalink) |
Freak Poster Join Date: Jun 2012 Location: Iran-Behbahan Age: 42
Member: 1778926 Status: Offline Thanks Meter: 60 | j710f remove pattern lock problem Operation: Reset Pattern Lock Selected model: SM-J710F Software version: 27.0 Checking local file... ok Searching server... not found Searching USB Flash interface... COM15 detected Setup connection... ok Reading data from phone... ok Sending data to phone... ok Sending data to phone... ok Waiting ADB device... ok Reading phone info... Recovery build version: Boot version: Platform: Boot serial: Product board: Erasing locks... ok Rebooting phone... ok Reset locks done Done with Samsung Tool PRO v.27.0 |
01-21-2017, 23:53 | #6 (permalink) | |
No Life Poster Join Date: Nov 2007 Location: Arizona Age: 38
Member: 630795 Status: Offline Thanks Meter: 177 | Quote:
Did u solve your problem bro ? if yes How? Thanks | |
04-14-2017, 08:40 | #7 (permalink) | |
Insane Poster Join Date: Jul 2013 Age: 35
Member: 1983825 Status: Offline Sonork: 100.1672058 Thanks Meter: 11 | I have same problem help us Quote:
05-20-2017, 08:34 | #8 (permalink) |
Freak Poster Join Date: Aug 2010 Location: iran
Member: 1368525 Status: Offline Thanks Meter: 23 | i have the same proble.i think custom recovery or aother program like z3x cant mount and access data folder in phone because when i install twrp cant mount data UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. Operation: Reset Pattern Lock Selected model: SM-J710F Software version: 28.1 Checking local file... Ok Searching server... not found Searching USB Flash interface... COM107 detected Setup connection... Ok Reading data from phone... Ok Sending data to phone... Ok Sending data to phone... Ok Waiting ADB device... Ok Reading phone info... Recovery build version: 6.0.1 Boot version: J710FXXU2APLD Platform: exynos7420 Boot serial: 52034b5b5b69c395 Product board: j7xelte Erasing locks... Ok Rebooting phone... Ok Reset locks done Done with Samsung Tool PRO v.28.1 |
