10-06-2015, 01:55 | #1 (permalink) |
Freak Poster Join Date: Sep 2012 Location: Egypt Age: 30
Member: 1815000 Status: Offline Thanks Meter: 54 | SCL22(N900J) unlock fail can't activate diag unlock new security fails in uart help !? what to do ? Can i downgrade safe to 4.4.2 or 4.3 and do the unlock process ? |
The Following User Says Thank You to Master-ZizO For This Useful Post: |
10-06-2015, 03:31 | #2 (permalink) | |
Freak Poster Join Date: Jul 2015
Member: 2424041 Status: Offline Thanks Meter: 10 | Quote:
Sent from my LG-H955 using Tapatalk | |
10-06-2015, 03:33 | #3 (permalink) |
Member: 2424041 Status: Offline Thanks Meter: 10 | If you already have the firmware then you can do that. If u don't have.. Just go to recovery mode. There 'll be an option for enabling cp logging Just enable that. Your problem will be solved |
10-06-2015, 03:33 | #4 (permalink) |
10-06-2015, 19:40 | #8 (permalink) |
Member: 1815000 Status: Offline Thanks Meter: 54 | *#0808# is not working i can't open diag port i downgraded to 4.4.2 can't downgrade to 4.3 |
03-11-2016, 21:30 | #9 (permalink) |
Insane Poster Join Date: Aug 2006 Location: Romania Age: 40
Member: 327867 Status: Offline Thanks Meter: 12 | Qulacomm USB drivers should be installed on PC first. Native Sumsung drivers should be unistalled. 1. Install phoneutil.apk (attached) 2. Install QuickShortCutMaker 3. Run QuickShortCutMaker -> find PhoneUtil -> expand it and choose "com.sec.android.app.phoneutil.SerPortUartUsbM SM89 60" as a shortcut. Shortcut will be placed on Home Screen 4. Disconnect phone from PC. 5. Run Shortcut. Choose MODEM ->Qualcomm USB Settings -> DM+MODEM+ADB -> Ok. 6. Connect to PC. Samsung_device. (CDC composite). For these devices i manually chose QC serial driver: Manual Driver Installation -> Chose preinstalled driver -> Ports (COM+LPT) -> Qualcomm Incorporated -> Qualcomm HS-USB Diagnostics 9004. Do it for both unknown devices. All you need is here: https://mega.nz/#!LhQ1lL5Z!gC6Y4mh9k...yHdDRBG2Z7526s |
