02-19-2018, 12:12 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: RMS- CLUB
Member: 723410 Status: Offline Sonork: 📱 100.1592732 Thanks Meter: 3,374 | J710F unlock Problem To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To read security codes via diagnostic port: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes DIAG' button to read security codes. Operation: Unlock Selected model: SM-J710F Software version: 30.8 Waiting ADB device... OK Reading phone info... Model: SM-J710F Android version: 6.0.1 Product code: SM-J710FZKUSER Phone version: J710FXXU4BQL3 PDA version: J710FXXU3AQF8 CSC version: J710FOXY3AQF2 CSC country code: Russia CSC sales code: SER HW version: MP 0.400 Phone SN: RF8J91NGHZZ Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-06-01 RF cal date: 20170915 IMEI: 355100083219526 Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... error (1 19) Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... error (0) Try downgrade modem if possible Done with Samsung Tool PRO v.30.8 |
