J710FN - Remove FRP not working Hi, J710FN frp remove not working...the combination file does not enable ADB... I've downloaded the COMBINATION_OXA_FA60_J710FXXU1APD2_OXA1APD2.zip Then i've choose to flash only boot.img, otherwise it will don't flash and return an error... Code: Operation: Flash Code: Operation: Reset FRP |
Up... Any idea? Also with new samsung tool pro...same problem |
J710FNDDU1APJ1 6.0.1 07.10.2016 Then use the COMBINATION_OXA_FA60_J710FXXU1APD2_OXA1APD2.zip combination file and then do FRP with Z3X |
If i flash both boot and sboot flash fail... Already try to restore the firmware with SmartSwitch in emergency mode...same problem when flashed the combination... Quote:
Code: File analysis... OK |
Bro you can bypass it with realterm or you can use the frpcall.exe app for the emergency call and bypass |
I can insert the new account but at reboot the frp still active... |
Up... Any solution? Thanks |
Remove FRP by Realterm TCP Terminal. Guide videos Available on youtube. |
At reboot the frp stil active and i cannot complete the wizard... |
