07-11-2017, 16:34 | #1 (permalink) |
Freak Poster Join Date: Feb 2014
Member: 2127758 Status: Offline Thanks Meter: 26 | J710FN - Remove FRP not working J710FN frp remove not working...the combination file does not enable ADB... I've downloaded the COMBINATION_OXA_FA60_J710FXXU1APD2_OXA1APD2.zip Then i've choose to flash only boot.img, otherwise it will don't flash and return an error... Code: Operation: Flash Selected model: SM-J710FN Software version: 28.1 File analysis... Ok Total file size: 0x00F42120 (15 Mb) Searching USB Flash interface... COM59 detected Setup connection... Ok Reading PIT from phone... Ok Sending boot.img... Ok Flashing done (time - 00:00:02) Done with Samsung Tool PRO v.28.1 Code: Operation: Reset FRP Selected model: SM-J710FN Software version: 28.1 Waiting ADB device... timeout Phone not found First activate ADB Done with Samsung Tool PRO v.28.1 |
07-12-2017, 18:32 | #3 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | Quote:
07-12-2017, 19:28 | #4 (permalink) | |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Quote:
J710FNDDU1APJ1 6.0.1 07.10.2016 Then use the COMBINATION_OXA_FA60_J710FXXU1APD2_OXA1APD2.zip combination file and then do FRP with Z3X | |
07-14-2017, 16:34 | #5 (permalink) | ||
Member: 2127758 Status: Offline Thanks Meter: 26 | Quote:
If i flash both boot and sboot flash fail... Already try to restore the firmware with SmartSwitch in emergency mode...same problem when flashed the combination... Quote:
Code: File analysis... OK Total file size: 0xAC675650 (2758 Mb) Searching USB Flash interface... COM59 detected Setup connection... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending cm.bin... error timeout Done with Samsung Tool PRO v.28.6 | ||
