12-08-2017, 03:52 | #1 (permalink) |
Freak Poster Join Date: Jun 2017
Member: 2730595 Status: Offline Thanks Meter: 13 | J727t1 frp done susccesfully i have done this perfectly first u need blue tooth head set then u conest ur phone with wifi after that u make emargency call ,there u can see bluetooh option connect ur blue tooth head set . then long press on blue tooth head set call button u can see there google listening window ,u just say google chrome ,,,,it will go chrome option ...then u type there calculator calculator menu will open now now u type there (+30012012732+ now u can see there ADB enable option ,enable adb option then reboot phone ... and connect with pc now u open z3x box select model j700t1 go to unlock tab ( u should select adb option at z3x window ) just reset frp( i have tested on android version 7) UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. To read security codes: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP Selected model: SM-J700T1 Software version: 29.8 Waiting ADB device... OK Reading phone info... Model: SM-J727T1 Android version: 7.0 Product code: SM2J727TZDATMK Phone version: J727T1UVU1AQG1 PDA version: J727T1UVU1AQG1 CSC version: J727T1TMK1AQG1 CSC country code: USA CSC sales code: TMK HW version: REV0.7 Phone SN: R28J53B174T Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-07-01 RF cal date: 20170526 IMEI: 355620082196094 Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.29.8 |
The Following User Says Thank You to dineshkannur123 For This Useful Post: |
