Old 06-21-2019, 13:35   #1 (permalink)
Member: 90307
Sonork: not hav e
Thanks Meter: 24
J730g oem unlock in combination file? only profissional can solve this problem ?
hi all bro i have j730g oem lock on cant off it to flash recovery or cf root
i find combination u6 and flash it ok fone is on but not have omn unlock option
when i flash full with or without home csc fone in recovery cant on
also cant root it becose oemm is on
how can solve it need help
is it oem unlockm in combination file?
FLASH INSTRUCTIONS:
1. Choose correct flash file(s).
2. If you have PIT file chosen, then you must check 'Repartition' option.
3. Check flashing options if needed (Repartition, EFS clear, Boot update).
4. Power on the phone in download mode (turn off phone, press vol.down + home + power).
5. Connect the phone to PC with USB cable, install drivers if needed.
6. Press 'Flash' button.
Operation: Flash
Selected model: SM-J730G
Software version: 36.8
File analysis... OK
Total file size: 0xF87B1700 (3975 Mb)
Searching USB Flash interface... COM11 detected
Setup connection... OK
Reading PIT from phone... OK
Sending sboot.bin.lz4... OK
Sending param.bin.lz4... OK
Sending cm.bin.lz4... OK
Sending boot.img.lz4... OK
Sending recovery.img.lz4... OK
Sending system.img.lz4... OK
Sending userdata.img.lz4... OK
Sending modem.bin.lz4... OK
Sending cache.img.lz4... OK
Sending hidden.img.lz4... OK
Flashing done (time - 00:04:09)
Done with Samsung Tool PRO v.36.8
Old 06-21-2019, 16:54   #2 (permalink)
safina gsm's Avatar
Member: 2906511
Thanks Meter: 136
which firmware version you used in phone?
Old 06-21-2019, 17:56   #3 (permalink)
Member: 90307
Sonork: not hav e
Thanks Meter: 24
i test many firmware u5 and now u6 XS6BSD1
Old 06-21-2019, 18:16   #4 (permalink)
farooquepm's Avatar
Member: 2424314
Thanks Meter: 731
Originally Posted by qassem View Post
i test many firmware u5 and now u6 xs6bsd1
you mean you want to root your mobile phone?
Old 06-21-2019, 18:49   #5 (permalink)
Member: 90307
Sonork: not hav e
Thanks Meter: 24
i want to use my fone only in combination fone is on but in full flash not on need to write root file to fully on but oem is on so cant wrte twrp or cf root
Old 06-21-2019, 18:50   #6 (permalink)
Cheater -Don't Deal with him-
Member: 1163999
Thanks Meter: 97
Phone work normal Mode?
The Following User Says Thank You to SPS+ For This Useful Post:
Old 06-21-2019, 18:50   #7 (permalink)
Member: 1163999
Thanks Meter: 97
Yes? To via cp mouse you need unlock oem.
Old 07-02-2019, 06:25   #8 (permalink)
Member: 90307
Sonork: not hav e
Thanks Meter: 24
any good news pleas3e
Old 07-16-2019, 10:07   #9 (permalink)
Member: 1488285
Thanks Meter: 28
i have a problem with my samsung sm-j730g binary 6, android version 9 pie. Globe lock need to unlock,,, action taken,1, i ****** not supported, 2 z3x with credits, and octopus with credits no luck. is there another solution?
Old 07-16-2019, 10:11   #10 (permalink)
Member: 1488285
Thanks Meter: 28
i root the phoe the result logo only. i try to flash succes but stiil. please help me thanks in advance
Old 07-25-2019, 07:24   #11 (permalink)
Member: 90307
Sonork: not hav e
Thanks Meter: 24
please text me in private
Page generated in 0.22089 seconds with 9 queries
