Old 06-19-2017, 08:06   #1 (permalink)
Member: 779599
Thanks Meter: 59
samsung n7502 hang up help
team i would like to ask: is it possible to flash this model even write protection is enable? if not how to do so?
heres my logs
FLASH INSTRUCTIONS:
1. Choose correct flash file(s).
2. If you have PIT file chosen, then you must check 'Repartition' option.
3. Check flashing options if needed (Repartition, EFS clear, Boot update).
4. Power on phone in download mode (turn off phone, press vol.down + home + power).
5. Connect phone to PC with USB cable, install drivers if needed.
6. Press 'Flash' button.
Operation: Flash
Selected model: SM-N7502
Software version: 28.1
File analysis... Ok
Total file size: 0x269A7B9C (617 Mb)
Searching USB Flash interface... COM62 detected
Setup connection... error
It looks like you have an unsucessful operation, try this link for solution - inurl:f453 site:http://forum.gsmhosting.com/ "Selected model: SM-N7502" "Setup connection error" - Пошук Google
Done with Samsung Tool PRO v.28.1
i tried to flash with the same firmware but sadly it cant why pls help
Old 06-19-2017, 11:07   #2 (permalink)
Member: 779599
Thanks Meter: 59
when i go to download mode it appears on the screen at the top that write protection enable i dont know how to fix this. team is it possible to fix this problem by flashing ? if possible how? pls help thanks
Old 06-19-2017, 11:11   #3 (permalink)
Member: 779599
Thanks Meter: 59
team, when i go to download mode it appears on the screen at the top that write protection enable. i dont know hw to fix this problem. team is it posible to fix this problem by flashing even it is protected? if possible how? pls help.
Page generated in 0.15144 seconds with 8 queries
