03-19-2016, 02:31 | #32 (permalink) |
Junior Member Join Date: Aug 2011
Member: 1644857 Status: Offline Thanks Meter: 4 | unlock scv31 is very easy to unlock scv31 there is 3 major ways: 1 first way is very expansive = use new cert file. 2 second way is = fellows 7 steps and you need z3x and spt box : 1. Flash COMBINATION file via Odin, AP tab 2. Go dial type *#0808# and change to DM + MTP + ADB 3. Use z3x Pro, switch to repair tab and reset MSL 4. Save original imei to notepad, open SPT box, use UART C3303k cable then choose scv31 unlocked imei (you can get it from yahoo or rekuten japan), super any imei supported 5. Enter download mode and reflash FULL file split BL,AP,CP,CSC and Pit 6. Connect wifi then go setting - status - status sim card and you will got an update,choose yes and update it 7. Repeat step 1,2,3 for repairing imei but super original imei before. 8. Final step,relfash stock FULL again,enjoy with unlocked phone. the 3 way is very simple and easy way you need only to send me your full backup by trwp i will put it into my phone unlocked the backup and returned the unlocked backup to you. |
The Following User Says Thank You to ridal2011 For This Useful Post: |
03-21-2016, 06:05 | #36 (permalink) |
Major Poster Join Date: Mar 2014
Member: 2144187 Status: Offline Thanks Meter: 202 | Please refer to this thread, you can get instruction + download link for this model: Chia s? - H??ng d?n unlock sim Samsung SCV31 (Samsung Galaxy S6 edge SCV31 au KDDI) | VIETMOBILE.VN ? CHUYÊN TRANG V? THI?T B? & ?I?N THO?I DI ??NG Last edited by vietmobile.vn; 03-21-2016 at 06:10. |
The Following User Says Thank You to vietmobile.vn For This Useful Post: |
03-21-2016, 12:35 | #37 (permalink) | |
No Life Poster Join Date: Mar 2008 Location: City of Temples
Member: 729381 Status: Offline Thanks Meter: 248 | Quote:
i got combination file here http://4share.vn/f/3a0e0d030b0a0b03/...noship.tar.rar | |
The Following User Says Thank You to bimes For This Useful Post: |
03-21-2016, 15:37 | #38 (permalink) |
Major Poster Join Date: Mar 2004 Age: 48
Member: 57535 Status: Offline Thanks Meter: 2 | Thank you ridal2011 for the reply and thanks a lot and vietmobile.vn for the reply and instructions and files Just two latest question is this a permanent unlock? Can I put custom rom like SPACEX rom? 'cos I need it for more languages thank you again |
03-22-2016, 06:27 | #39 (permalink) | |
Member: 2144187 Status: Offline Thanks Meter: 202 | Quote:
https://drive.google.com/file/d/0B7M...w?pref=2&pli=1 Password : fullscv31 | |
The Following 4 Users Say Thank You to vietmobile.vn For This Useful Post: |
03-24-2016, 00:09 | #40 (permalink) | |
Member: 1644857 Status: Offline Thanks Meter: 4 | Quote:
be carfull you must make a full backup by trwp before using the 7 steps ok send me your email i will help you | |
03-24-2016, 10:45 | #41 (permalink) |
Freak Poster Join Date: Mar 2007 Location: In the skies
Member: 460298 Status: Offline Thanks Meter: 32 | After unlock as instruction, you can flash custom rom make for SCV31. This is pernament unlock |
The Following User Says Thank You to gemini16 For This Useful Post: |
04-08-2016, 08:09 | #42 (permalink) | |
No Life Poster Join Date: Mar 2004 Location: Cambodia
Member: 59030 Status: Offline Thanks Meter: 165 | Quote:
Thanks for your help. | |
04-08-2016, 12:16 | #43 (permalink) | |
04-09-2016, 09:54 | #45 (permalink) |
Member: 59030 Status: Offline Thanks Meter: 165 | First, big thanks to vietmobile.vn for sharing the files and ridal2011 for the instruction. I finally got it to work with the help of user: gayansuranga. The step that I didn't do right was the update part where I have to go to Settings>About>SIMlock Status to update, not the phone software update. Here's what I've done: BEFORE DOING ANYTHING, WRITE DOWN THE ORIGINAL IMEI # somewhere. Make sure you know the original IMEI 1). Flash Combination file using Odin. After flashing, phone will be in Factory Binary Mode. Tab one Android logos at the bottom of the screen to get to dial pad and enter *#0808# and select DM+MTP+ADB then OK. 2). Use Z3X, select the SCV31 model and go to Repair tab and press on Reset MSL. 3). Write down the phone's original IMEI# somewhere and save it. Use SPT box. Select model G900H and go to Service tab and in Repair IMEI, enter this super IMEI : 358012060753038 (this is an original factory unlocked IMEI) Use C3300 UART cable. and write new IMEI to phone. After it finished, check to make sure you have the new IMEI in phone. 4). Flash FULL flash files (BL, AP, CP, CSC) and no need PIT file, using Odin. 5). After flashing full flash files, inset any SIM card, phone boots up and go to WIFI and turn on. Go to Settings>>About>>SIM card status. You should see Status: Not allowed. Tab on "Update SIM card status" at the bottom of the screen then wait until it finished and reboot. Go back to SIM card Status again and see if it shows Status: Allowed. If it is, then you're good to go to the next steps. 6). Repeat Step 1,2, and 3, except in Step 3, enter phone's ORIGINAL IMEI. After all steps done, check to make sure you have original IMEI in phone now. 7). Now flash FULL flash files (BL,AP,CP,CSC) again. After flashing is done, phone should be now UNLOCKED. If you want to remove AU Japanese contents in ROM, you can flash this SPACX ROM using Odin: https://www.androidfilehost.com/?fid=24052804347770225 Hope this will help members who need to unlock and not getting scammed by those who are taking advantage of this FREE solution. Thanks to user: gayansuranga of cellular friends CF who took the time to help me. |
The Following 2 Users Say Thank You to citifone For This Useful Post: |
