Ku990i restarting in LG Logo!! hi z3x team...i need help in lg ku990i rstarting in lg logo after flashing modem still rebooting in lg logo here is the log: v.1.8.0 supported models: 91 andrew_tm 2009(c) ;) Reading file as KU990i... Ok Original Firmware file: KU990i-DZ-V10b-MAR-12-2009-OPN-EU Mode: Emergency Model: KU990 Elapsed: 0 secs. Mode: Emergency Model: KU990 Elapsed: 0 secs. Start Flash... Modem Write Start... Flash Verify Done. EFS Erase Done. Modem Write Done. Phone Reboot. Phone Detected! Port already opened! EFS Write Error! Elapsed: 911 secs. EFS write error coz ku990i not go in normal mode or refreshing in yellow background.. please i need little help... phone leave by *******r :D marvin.. |
chek the correct module ku990i,ku990g,ku990 chek the module then flash the phone |
restarting in lg logo... any one having original flasher and flashfile of it? please need help...:confused: |
any solution.......... |
Extract .DZ file then use furious to repair OTP ImEI by flashing KU990i.bin then flash it with (LGMDP_OPEN.exe) using extracted file................ note: To enable EMERGENCY DOWNLOAD PRESS GREEN KEY + "C" KEY + KEY LOCK BUTTON + POWER ON. |
In your pc bad usb or you use bad cable. Check in options Manual phone readiness confirmation and press flash button :) After flash modem software ask you, disconnect phone and connect again after this press Ok button in software :) -- andrew_tm 2010 :) |
Change cable or put usb in pc |
ok let me try all solution youve got ill post result later |
where can i find free software but i dont have fg only Z3x lg only... |
i do the same way after software ask and then reconnect phone nothing happen still phone in restarting... i flash phone with diffrent firmware of ku990i from support but still restarting ....any solution.. i used this 3 files from support: KU990i-DZ-V10a-FEB-25-2009-BYT-FR.crp KU990i-DZ-V10b-MAR-12-2009-OPN-EU.crp KU990i-DZ-V10c+2-MAR-12-2009-H3G-GB.crp whats next:confused::confused::confused: |
If not passed with z3x i don't think it will be passed with free Software but you can try with free flasher ku990i it's same ku990 so you can use free ku990 flasher and select ku990i firmware Good luck |
what was the problem before flashing? if flash is ok and phone still reboot maybe hardware problem. |
before it was in yellow background and "refreshing" i saw this before my *******r came back its in rebooting mode only lg logo so i decide to flash with z3x lg... i tried 3 firmwares from support of ku990i but problem still persist..:confused: |
http://www.****************/lg.htm |
