12-04-2009, 12:01 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Nov 2006
Member: 390492 Status: Offline Thanks Meter: 67 | z3x team need help pls Code: Selected model: C5212_s Selected com port: COM9 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 3B11 Sending loader2... OK Flash ID: 00EC2206000100000034 Slave Detected Sending slave loader1... OK ARM version slave 3541 Sending slave loader2... OK Flash ID: 00EC240200010000E1D0 NAND format - ок Start NOR flash NOR flash - ok Start Flash TFS Mount NAND - ok Create DIR - ok TFS - Fail Send TFS - fail Elapsed time: 737 second, sw ver: 3.4.0014 ------------------------------------------------------------------------------- Selected model: C5212_m Selected com port: COM9 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 3B11 Sending loader2... OK Flash ID: 00EC2206000100000034 NAND format - ок Start NOR flash NOR flash - ok Start Flash TFS Mount TFS - ok Create DIR - ok Download - ok Elapsed time: 1443 second, sw ver: 3.4.0014 ------------------------------------------------------------------------------- Selected model: C5212_m Selected com port: COM9 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 3B11 Sending loader2... OK Flash ID: 00EC2206000100000034 Write EEP - ok Elapsed time: 42 second, sw ver: 3.4.0014 ------------------------------------------------------------------------------- Selected model: C5212_m Selected com port: COM9 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 35283203015969 Phone SW: C5212XAIC7 Phone BT ADDR: 0021-D1-6554F5 Phone SN: RPNS327449 Deactivated MSL - TRUE Selected model: C5212_m Selected com port: COM9 Selected speed port: 921600 Write imei - ok Repair - ok Elapsed time: 11 second, sw ver: 3.4.0014 flash done all OK phone starts up without simcard all ok but when insert simcart phone hangs on start logo whats the sollution for this ? best regards |
12-04-2009, 13:58 | #3 (permalink) |
Member: 390492 Status: Offline Thanks Meter: 67 | bro phone was 100% working phone i had to flash for my *******r to an spanish language after flash and all phone not start with simcard hangs on logo without simcard phone does start thats realy weird if there was an hardware problem than phone shouldnt even start without simcard also. best regards |
12-04-2009, 14:36 | #4 (permalink) |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Selected model: C5212_s Selected com port: COM9 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 3B11 Sending loader2... OK Flash ID: 00EC2206000100000034 Slave Detected Sending slave loader1... OK ARM version slave 3541 Sending slave loader2... OK Flash ID: 00EC240200010000E1D0 NAND format - ок Start NOR flash NOR flash - ok Start Flash TFS Mount NAND - ok Create DIR - ok TFS - Fail Send TFS - fail Elapsed time: 737 second, sw ver: 3.4.0014 Problem in slave tfs flashing. check options format tfs. |
12-04-2009, 15:10 | #5 (permalink) |
Member: 390492 Status: Offline Thanks Meter: 67 | mr blanq there are to versions of C5212 samsung in the list you have the c5212_s and c5212_m version and the phone is just C5212 which of this models do i need to choice . best regards |
12-04-2009, 15:18 | #6 (permalink) |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | i alread told in same tread. please next time use search button, phone have 2 part: 2 dir phone inside: master and slave. need flash each part main + tfs. first flash master , second flash slave. flash file is different for each part. 4 dif files. |
z3x team need help | aljolas | QUALCOMM Models (3G) | 6 | 11-25-2009 08:21 |
cyclone team need help pls | Gago_ | Cyclonebox | 1 | 10-31-2009 23:58 |
Pls help Z3x Team Mr.Blang pls help E250 prob | mali_comm | Z3X-Team Products | 1 | 10-21-2009 18:31 |
FG team need help pls. | Gago_ | FuriousGold | 3 | 10-13-2009 14:43 |
