12-07-2013, 18:37 | #1 (permalink) |
No Life Poster Join Date: Mar 2005 Location: gsmwebstore
Member: 125366 Status: Offline Sonork: 100.1602649 Thanks Meter: 108 | L720 unlock finaly done process that u can.... What you need: An extracted FirmwareAIO.tar.md5 from the second post Odin (I used 3.07, but I am pretty sure others work too) A PC... (duh) Sprint Galaxy S4 A brain Here is the procedure: Power OFF the phone (do not use reboot to download mode, do a full power off) Hold down the Volume down key and then press and hold the power Key. When the screen lights up, release both Press Volume up to Continue past the first screen, you should now be in Download Mode. Plug the phone into the PC with Odin Fire up Odin and select the modem tar.md5 file with the PDA button Click Start and Let it flash until it's done. It will auto reboot and you'll be all set. NOTE: With MJA Firmware, some people report better success with turning Auto Reboot and F. Reset Time unchecked. Do the same flash, but when you see PASS on Odin, unplug the phone and Hold the Power key for 10 seconds to reboot Link is here MDLFirmwareAIO.tar.md5.zip | by Unknownforce for Galaxy S4 After unlock Z3x All done |
