Old 01-25-2017, 08:55   #1 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 173,480
LG 2-3G Tool 9.32 Release. LG V20, LG X Mach
Added:
- support H540D (read unlock codes, imei repair, flashing, firmware maker, read/write security zone, screen lock reset)
- support H900 (direct unlock)
- support H915 (direct unlock, imei repair, flashing, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, FRP reset)
- support H918 (imei repair, flashing, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, FRP reset)
- support H918TN (imei repair, flashing, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, FRP reset)
- support H990TR (direct unlock, imei repair, flashing, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, FRP reset)
- support K600 (direct unlock, imei repair, flashing, firmware maker, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, screen lock reset, FRP reset)
- support K600HK (direct unlock, imei repair, flashing, firmware maker, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, screen lock reset, FRP reset)
- support K600Y (direct unlock, imei repair, flashing, firmware maker, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, screen lock reset, FRP reset)
* Some bug fix
Special for some users added options: Write user data and misc. If you check this checkbox and write firmware software not skip user data and misc partition.
Multi-language interface - for translate use Z3X LG 2-3G Tool (Z3X LG 2-3G Tool)
Mega: link
The Following 46 Users Say Thank You to blang For This Useful Post:
Old 01-25-2017, 09:33   #2 (permalink)
Member: 1912347
Thanks Meter: 18
Thanks Z3X Team ............................
Old 01-25-2017, 09:41   #3 (permalink)
Member: 2649205
Thanks Meter: 2
wow really helpful gift present for ours mr blang. request to you support frp reset via download mode without adb mode.
Old 01-25-2017, 10:45   #4 (permalink)
haji rahim's Avatar
Member: 723410
Sonork: 📱 100.1592732
Thanks Meter: 2,348
Please add support for sprint phones, ls675, ls676, ls450, lg x power, ls775. Add apn option and unlock.
[/UR
The Following 7 Users Say Thank You to haji rahim For This Useful Post:
Old 01-25-2017, 11:05   #5 (permalink)
Member: 455304
Thanks Meter: 310
need unlocking support for 7.0 andriod version
Old 01-25-2017, 11:06   #6 (permalink)
Member: 694980
Thanks Meter: 67
Z3x LG is an excellent tool. Congratulations
We need MTK platform support!
Do you have plans to add MTK?
Old 01-25-2017, 11:50   #7 (permalink)
Member: 2377800
Sonork: nono
Thanks Meter: 27
Please add support for lg 5x nexsus h791f
The Following User Says Thank You to mohacraft For This Useful Post:
Old 01-25-2017, 13:07   #8 (permalink)
Member: 2636022
Thanks Meter: 6
We need this update Z3X is being behind Octoplus for this ...dd support for sprint phones, ls675, ls676, ls450, lg x power, ls775. Add apn option and unlock.
The Following 2 Users Say Thank You to lexisvz For This Useful Post:
Old 01-25-2017, 13:48   #9 (permalink)
Member: 2489690
Thanks Meter: 119
great work team.........
Old 01-25-2017, 13:49   #10 (permalink)
Member: 2437116
Thanks Meter: 24
Imei repair is not working properly on h918.either I don't get a port or I fget a "battery to low,change the battery" error
mr blang pls advise
The Following User Says Thank You to fuentesadalid0 For This Useful Post:
Old 01-25-2017, 15:35   #11 (permalink)
RanaBhai's Avatar
Member: 2112799
Thanks Meter: 73
is possible read firmware of supported lg phones by z3x lg tool ????
The Following User Says Thank You to RanaBhai For This Useful Post:
Old 01-26-2017, 02:11   #12 (permalink)
luisy's Avatar
Member: 2352896
Thanks Meter: 100
When will you have a solution to unlock LS997 on android 7.0???
The Following 2 Users Say Thank You to luisy For This Useful Post:
Old 01-26-2017, 07:28   #13 (permalink)
Member: 2484556
Sonork: 100.1670147
Thanks Meter: 7
Any news for lg k7 ms330 unlock?
Old 01-26-2017, 10:28   #14 (permalink)
Member: 2379348
Thanks Meter: 15
UNLOCK INSTRUCTIONS:
1. Power on the phone.
2. Type *#0808# and select 'DM+MODEM+ADB'.
3. Type *#9090# and select 'DM/DUN over HSIC'.
Or use 'Activate Diag' function from 'Repair' tab.
4. Connect phone to PC with USB cable, install drivers if needed.
5. Select diagnostic port in port settings.
6. Press 'Unlock' button for direct unlock.
To reset Google account activation lock:
1. ADB must be activated in any way (you can flash sBoot from combination firmware,
make sure, that you are not upgrade sBoot).
2. Connect phone to PC with USB cable, install drivers if needed.
3. Select device in ADB settings.
4. Press 'Reset FRP' and follow the instructions in program.
5. When process done, press 'Back' on phone and perform factory reset from phone settings.
To reset Google account activation or Samsung reactivation lock:
1. Power on phone in download mode (turn off phone, press vol.down + home + power).
3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
4. After phone reboot, go to settings and perform factory reset.
Operation: Unlock
Selected model: SM-J500FN
Selected port: COM16 SAMSUNG Mobile USB Serial Port
Software version: 27.7
Reading phone info...
Reading IMEI... Ok
IMEI: 358321079529358
Unlocking... error (0)
Done with Samsung Tool PRO v.27.7 j500fn unlock problam
Old 01-26-2017, 15:41   #15 (permalink)
Member: 1827470
Sonork: 101306
Lg p880 no add flashing firmware unlock and etc..please add lg p880 to the list
Page generated in 0.36278 seconds with 7 queries
