Old 04-08-2017, 11:20   #61 (permalink)
Member: 190274
Thanks Meter: 41
Originally Posted by andrew_tm View Post
We can't detect old and new algo. We will try make this.
Also, phone still is no service even after unlock. Will flash with same firmware and try unlock again...
Old 04-08-2017, 11:35   #62 (permalink)
Member: 1908127
Thanks Meter: 6
add new model zte xiaomi and huawei man
Old 04-09-2017, 05:22   #63 (permalink)
Member: 1228709
Thanks Meter: 218
Hi dear andrew, what about this error?
08/04/2017 09:27:24 p.m.: LG 2-3G Tool v9.34
08/04/2017 09:27:24 p.m.: supported models: 1445
08/04/2017 09:27:44 p.m.: Mode: Emergency
08/04/2017 09:27:45 p.m.: Model: K530F
08/04/2017 09:27:45 p.m.: Read info...
08/04/2017 09:27:47 p.m.: Model name: LG-K530F
08/04/2017 09:27:47 p.m.: Software verion: K53010c
08/04/2017 09:27:47 p.m.: Android verion: 6.0.1
08/04/2017 09:27:47 p.m.: IMEI: 357883072160508
08/04/2017 09:27:47 p.m.: Elapsed: 4 secs. --> (v9.34)
08/04/2017 09:28:28 p.m.: Mode: Emergency
08/04/2017 09:28:29 p.m.: Model: K530F
08/04/2017 09:28:29 p.m.: Read info...
08/04/2017 09:28:30 p.m.: Model name: LG-K530F
08/04/2017 09:28:30 p.m.: Software verion: K53010c
08/04/2017 09:28:30 p.m.: Android verion: 6.0.1
08/04/2017 09:28:30 p.m.: IMEI: 357883072160508
08/04/2017 09:28:30 p.m.: Elapsed: 4 secs. --> (v9.34)
08/04/2017 09:28:32 p.m.: Phone mode is
08/04/2017 09:28:33 p.m.: DOWNLOAD
08/04/2017 09:28:33 p.m.: Start FRP remove...
08/04/2017 09:28:34 p.m.: Model name: LG-K530F
08/04/2017 09:28:34 p.m.: Software verion: K53010c
08/04/2017 09:28:34 p.m.: Android verion: 6.0.1
08/04/2017 09:28:34 p.m.: IMEI: 357883072160508
08/04/2017 09:28:34 p.m.: Laf cmd error: LAF_CMD_UNKNOWN fail[LAF_ERROR_FAILED].
08/04/2017 09:28:34 p.m.: Laf cmd error: LAF_CMD_RESERVED fail[LAF_ERROR_FAILED].
08/04/2017 09:28:34 p.m.: Could not init write data, maybe your filesystem is encrypted.
08/04/2017 09:28:34 p.m.: Error reset locks
08/04/2017 09:28:34 p.m.: Elapsed: 2 secs. --> (v9.34)
08/04/2017 09:29:55 p.m.: Mode: Emergency
08/04/2017 09:29:56 p.m.: Model: K530F
08/04/2017 09:29:56 p.m.: Read info...
08/04/2017 09:29:58 p.m.: Model name: LG-K530F
08/04/2017 09:29:58 p.m.: Software verion: K53010c
08/04/2017 09:29:58 p.m.: Android verion: 6.0.1
08/04/2017 09:29:58 p.m.: IMEI: 357883072160508
08/04/2017 09:29:58 p.m.: Elapsed: 4 secs. --> (v9.34)
08/04/2017 09:30:08 p.m.: Mode: Emergency
08/04/2017 09:30:09 p.m.: Model: K530F
08/04/2017 09:30:09 p.m.: Read info...
08/04/2017 09:30:11 p.m.: Model name: LG-K530F
08/04/2017 09:30:11 p.m.: Software verion: K53010c
08/04/2017 09:30:11 p.m.: Android verion: 6.0.1
08/04/2017 09:30:11 p.m.: IMEI: 357883072160508
08/04/2017 09:30:11 p.m.: Elapsed: 4 secs. --> (v9.34)
08/04/2017 09:30:33 p.m.: Phone mode is
08/04/2017 09:30:33 p.m.: DOWNLOAD
08/04/2017 09:30:33 p.m.: Start FRP remove...
08/04/2017 09:30:35 p.m.: Model name: LG-K530F
08/04/2017 09:30:35 p.m.: Software verion: K53010c
08/04/2017 09:30:35 p.m.: Android verion: 6.0.1
08/04/2017 09:30:35 p.m.: IMEI: 357883072160508
08/04/2017 09:30:35 p.m.: Init EXT4 ...
08/04/2017 09:30:37 p.m.: Save EXT4...
08/04/2017 09:30:38 p.m.: Laf cmd error: LAF_CMD_WRITE fail[LAF_ERROR_UNKNOWN[80000121]].
08/04/2017 09:30:38 p.m.: Error reset locks
08/04/2017 09:30:38 p.m.: Elapsed: 6 secs. --> (v9.34)
08/04/2017 09:31:40 p.m.: Mode: Emergency
08/04/2017 09:31:41 p.m.: Model: K530F
08/04/2017 09:31:41 p.m.: Read info...
08/04/2017 09:31:43 p.m.: Model name: LG-K530F
08/04/2017 09:31:43 p.m.: Software verion: K53010c
08/04/2017 09:31:43 p.m.: Android verion: 6.0.1
08/04/2017 09:31:43 p.m.: IMEI: 357883072160508
08/04/2017 09:31:43 p.m.: Elapsed: 5 secs. --> (v9.34)
08/04/2017 09:31:46 p.m.: Phone mode is
08/04/2017 09:31:47 p.m.: DOWNLOAD
08/04/2017 09:31:47 p.m.: Start FRP remove...
08/04/2017 09:31:49 p.m.: Model name: LG-K530F
08/04/2017 09:31:49 p.m.: Software verion: K53010c
08/04/2017 09:31:49 p.m.: Android verion: 6.0.1
08/04/2017 09:31:49 p.m.: IMEI: 357883072160508
08/04/2017 09:31:49 p.m.: Init EXT4 ...
08/04/2017 09:31:51 p.m.: Save EXT4...
08/04/2017 09:31:52 p.m.: Laf cmd error: LAF_CMD_WRITE fail[LAF_ERROR_UNKNOWN[80000121]].
08/04/2017 09:31:52 p.m.: Error reset locks
08/04/2017 09:31:52 p.m.: Elapsed: 6 secs. --> (v9.34)
Tested on new algo, and old algo
The Following User Says Thank You to JorgeVla For This Useful Post:
Old 04-10-2017, 03:08   #64 (permalink)
Member: 2574670
The function of the blackberry serves 100 to repair imei?
Old 04-10-2017, 08:30   #65 (permalink)
Member: 2661439
Thanks Meter: 12
i use reset f700L ver 11d, not work
Old 04-10-2017, 10:48   #66 (permalink)
Member: 2304080
Thanks Meter: 31
lg ls 980 firmware in the shell is incorrect or damaged
[IMG][/IMG]
Old 04-10-2017, 13:48   #67 (permalink)
Member: 1880500
Boostmobile lgs770 is CDMA. If I do direct unlock with this software the GSM will be activated in the phone?
sorry for my english
thanks in advance
Old 04-10-2017, 14:00   #68 (permalink)
Member: 2684440
Thanks Meter: 97
This device is fully cdma...Don't work on any GSM network, you can check the hardware info in Google or boost Mobile website
Enviado desde mi KIW-L24 mediante Tapatalk
Old 04-10-2017, 15:42   #69 (permalink)
Member: 2304080
Thanks Meter: 31
lg LS980ZVC not red nvram
can't repair imei
LG 2-3G Tool v9.34
Mode: Normal
Model: LS980ZVC
Build version: Mar 9 201411:36:00Feb 25 201420:00:00LS980ZVC
SW Version: M8974A-AAAANAZM-2.0.20046
IMEI: 35xxxxxxxx1x-x
BlueTooth Address: 00:00:00:00:00:00
Phone Code:
Elapsed: 1 secs. --> (v9.34)
NV read...
Error read block: 85
Elapsed: 14 secs. --> (v9.34)
Mode: Normal
Model: LS980ZVC
Phone Code:
This phone are not supported!
Old 04-10-2017, 20:52   #70 (permalink)
Member: 927458
Thanks Z3X
FRP and Firmware
LG 2-3G Tool v9.34
Reading timeout, check cable
Error Code: ReadInfo,1,1
Elapsed: 3 secs. --> (v9.34)
Mode: Emergency
Model: K520TR
Read info...
Model name: LG-K520TR
Software verion: K52020f
Android verion: 7.0
IMEI: 3***********
Mode: Emergency
Model: K520TR
Read info...
Android verion: 7.0
IMEI: 3***********
Phone mode is DOWNLOAD
Start FRP remove...
Android verion: 7.0
IMEI: 3*************
Init userdata...
Init EXT4 ...
Init EXT4 ...
Save EXT4...
FRP Reset Done.
Elapsed: 129 secs. --> (v9.34)
The Following User Says Thank You to sahilkentli For This Useful Post:
Old 04-10-2017, 20:58   #71 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,063
For F700 try select H850 and report.
Old 04-14-2017, 04:22   #72 (permalink)
Member: 92260
Thanks Meter: 612
1-2 weeks they will copy
They finally copied it, released today "work with the signed versions of firmware..blah blah.." hehe
USB sniffers working overtime... But we will not forget who was first in the world
Old 04-18-2017, 07:15   #73 (permalink)
Member: 92260
Thanks Meter: 612
can't repair imei
LG 2-3G Tool v9.34
Mode: Normal
Model: LS980ZVC
Phone Code:
NV read...
Mode: Normal
Model: LS980ZVC
Phone Code:
We had a similar issue with several other models, told Andrew and he fixed them all. Maybe a "skip" of certain items will fix this one too.
Old 04-18-2017, 10:27   #74 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,063
Open manual in Model tab and check Read RAM section. If you not see section then this function not supported.
You can check LG activation | z3x-team here too.
The Following User Says Thank You to andrew_tm For This Useful Post:
Old 04-18-2017, 15:19   #75 (permalink)
Member: 2633816
Thanks Meter: 2
lg2 g3 tools erro acess violation at address 00867060 how to solve??
Page generated in 0.37180 seconds with 7 queries
