Old 07-19-2017, 20:46   #16 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
Originally Posted by rayyu168 View Post
LG 2-3G Tool v9.38
supported models: 1513
Mode: Normal
Model: LGM151AT
Build version: Jan 15 201719:35:19Dec 13 201623:00:00LGM151AT
SW Version: MPSS.JO.2.0.c1.2-00007-8909_GEN_PACK-1.80814.1_80783.1
IMEI: 35457608032935-3
BlueTooth Address: 00:00:00:00:00:00
Phone Code:
SPC: 000000
Elapsed: 1 secs. --> (v9.38)
Mode: Normal
Model: LGM151AT
BlueTooth Address: 00:00:00:00:00:06
Phone Code:
SPC: 000000
Direct unlock
Working with security zone
Checking phone at COM4
Reboot phone
Phone detected!
Repair IMEI...
Search LG Modem port...
Detected LG Modem port at COM5
Reboot phone
Done
Elapsed: 54 secs. --> (v9.38)
after unlock , i dial 2945#*151# and check unlock status , i select the first one , network unlock , it still showing network still lock and its asking for a unlock code
Select H850 and try make unlock. Post result.
Old 07-20-2017, 03:01   #17 (permalink)
Member: 1001056
Thanks Meter: 5
Select model H850 to unlock lg m151 instead , unlock ok but after the imei is turn 0
LG 2-3G Tool v9.38
Mode: Normal
Model: LGM151AT
Phone Code:
Mode: Normal
Model: LGM151AT
Phone Code:
Detected ID: 0000100C (MSM8909)
Reading ESN... OK
Read SPC...
Unlock SPC... OK
Backuping RFNV... OK
Backuping Feature Mask... OK
Backuping NV Item... OK
Backuping NV Item SIM1... OK
Backuping NV Item SIM2... OK
Backuping Provisioning Item Files... OK
Phone mode is NORMAL
Switch to DOWNLOAD mode
Phone detected!
Read security zone...
Model name: LG-M151
Software verion: M15110a
Android verion: 6.0.1
Target operator: GLOBAL
Target country: CA
IMEI: 354576080329353
Save part1... done
Save part2... done
Save part3... done
Sec zone saved: ..\Backup\H850_354576080329353_19072017_193736.lgs b1
Write security zone...
Erase part1... done
Erase part2... done
Erase part3... done
Reboot...
Phone detected!
Reading QCN file... OK
Unlock SPC... OK
Checking paths... OK
Restoring EFS Backup... OK
Restoring NV Items... OK
Restoring NV Item SIM1... OK
Restoring NV Item SIM2... OK
Restoring Provisioning Item Files... OK
Unlock done!
Elapsed: 299 secs. --> (v9.38)
Mode: Normal
Model: LGM151AT
BlueTooth Address: 42:00:00:00:02:00
Phone Code:
Not supported for this phone!
Repair IMEI...
Repair done!
Elapsed: 49 secs. --> (v9.38)
Repair IMEI...
Repair done!
Elapsed: 112 secs. --> (v9.38)
after unlock , i dial 2945#*151# and check unlock status , all 5 locks saying this phone is permanently locked , and can not be unlocked
it seems its full unlock and ready to go
but the scary part is the imei # , it turn to one 0 , so what i did is , in the section repair , i use imei 0 fix and enter the imei# manually , then after i reboot the phone , all the original imei # was back
but unlock this way make me nervous , not sure if i unlock it this way will do me harm , or will damage the phone signal or some other unknow issue might occur
Old 07-20-2017, 10:56   #18 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
rayyu168: about "phone is permanently locked" is ok.
Old 07-20-2017, 16:15   #19 (permalink)
Member: 229358
Thanks Meter: 12
Originally Posted by blang View Post
LG 2-3G Tool 9.38. LG Stylo 2, LG K4 2017, LG K10 2017, LG Stylus 3,...
Added:
- support K540 (direct unlock, imei repair, flashing, firmware maker, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, FRP reset)
- support M150 (direct unlock, imei repair, flashing, firmware maker, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, FRP reset)
- support M151 (direct unlock, imei repair, flashing, firmware maker, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, FRP reset)
- support M153 (direct unlock, imei repair, flashing, firmware maker, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, FRP reset)
- support M154 (direct unlock, imei repair, flashing, firmware maker, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, FRP reset)
- support M160 (direct unlock, imei repair, flashing, firmware maker, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, FRP reset)
- support M160E (direct unlock, imei repair, flashing, firmware maker, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, FRP reset)
- support M200E (read unlock codes, imei repair, flashing, firmware maker, read/write security zone)
- support M200N (read unlock codes, imei repair, flashing, firmware maker, read/write security zone)
- support [COLOR="Lime"]M210 (imei repair, flashing, firmware maker, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, FRP reset)
- support M250 (read unlock codes, imei repair, flashing, firmware maker, read/write security zone)
- support M250AR (read unlock codes, imei repair, flashing, firmware maker, read/write security zone)
- support M250DS (read unlock codes, imei repair, flashing, firmware maker, read/write security zone)
- support M250DSN (read unlock codes, imei repair, flashing, firmware maker, read/write security zone)
- support M250E (read unlock codes, imei repair, flashing, firmware maker, read/write security zone)
- support M250F (read unlock codes, imei repair, flashing, firmware maker, read/write security zone)
- support M250H (read unlock codes, imei repair, flashing, firmware maker, read/write security zone)
- support M250I (read unlock codes, imei repair, flashing, firmware maker, read/write security zone)
- support M250K (read unlock codes, imei repair, flashing, firmware maker, read/write security zone)
- support M250M (read unlock codes, imei repair, flashing, firmware maker, read/write security zone)
- support M250N (read unlock codes, imei repair, flashing, firmware maker, read/write security zone)
- support M250Y (read unlock codes, imei repair, flashing, firmware maker, read/write security zone)
- support M250YK (read unlock codes, imei repair, flashing, firmware maker, read/write security zone)
- support M257 (direct unlock, imei repair, flashing, firmware maker, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, FRP reset)
- support M257PR (direct unlock, imei repair, flashing, firmware maker, qcn read/write, nvm read/write, sec zone read/write/reset in flash/adb mode, FRP reset)
- support M400AR (read unlock codes, imei repair, flashing, firmware maker, read/write security zone)
- support M400DF (read unlock codes, imei repair, flashing, firmware maker, read/write security zone)
- support M400DK (read unlock codes, imei repair, flashing, firmware maker, read/write security zone)
- support M400DY (read unlock codes, imei repair, flashing, firmware maker, read/write security zone)
- support M400F (read unlock codes, imei repair, flashing, firmware maker, read/write security zone)
- support M400MT (read unlock codes, imei repair, flashing, firmware maker, read/write security zone)
- support M400N (read unlock codes, imei repair, flashing, firmware maker, read/write security zone)
- support M400Y (read unlock codes, imei repair, flashing, firmware maker, read/write security zone)
+ Updated FRP reset algo for lot of models.
* Fixed some bugs
Mega: LINK
P.S. We work for add FRP reset on M - series.
H961N screen lock reset error AND flashing error , please help :
LG 2-3G Tool v9.38
Mode: Emergency
Model: H961N
Read info...
Model name: LG-H961N
Software verion: H961N30a
Android verion: 7.0
Target country: COM
IMEI: 353829072395937
Elapsed: 4 secs. --> (v9.38)
Phone mode is DOWNLOAD
Start reset screen locks...
Android verion: 7.0
Target country: COM
Init EXT4 ...
Truncate file 0... done
Truncate file 1... done
Truncate file 2... done
Truncate file 3... done
Truncate file 4... done
Truncate file 5... done
Save EXT4...
Laf cmd error: LAF_CMD_WRITE fail[LAF_ERROR_UNKNOWN[80000121]].
Error reset locks
Elapsed: 245 secs. --> (v9.38)
Mode: Emergency
Model: H961N
Read info...
Android verion: 7.0
Target country: COM
Elapsed: 3 secs. --> (v9.38)
Start flashing.
Open KDZ File : D:\Mobile Repair\LG\H961N\H961N20k_00_0909.kdz
Checking file hash...
Model : LG-H961N
SwVersion : LGH961NAT-00-V20k-GLOBAL-COM-SEP-09-2016+0
BuildTime : 0000-00-00 00:00:00
Total Files : 69
Android verion: 7.0
Target country: COM
Laf cmd error: LAF_CMD_UNLINK fail[LAF_ERROR_FAILED].
Start direct download mode
Write "PrimaryGPT" partition #1 of 69
Direct download error.
Flashing error.
Elapsed: 20 secs. --> (v9.38)
Old 07-20-2017, 17:10   #20 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
LG 2-3G Tool v9.38
Mode: Emergency
Model: H961N
Read info...
Android verion: 7.0
Target country: COM
Android verion: 7.0
Target country: COM
Init EXT4 ...
Save EXT4...
Error reset locks
Mode: Emergency
Model: H961N
Read info...
Android verion: 7.0
Target country: COM
Start flashing.
Model : LG-H961N
Total Files : 69
Android verion: 7.0
Target country: COM
Flashing error.
Your phone with new signed firmware. You can't flash in phone firmware without signature and you can't make reset screen lock.
For reset screen lock put phone in download mode, check in options:
- flash in direct mode
- erase user data after flash
and flash in phone H961N 30a or newer version.
Old 07-21-2017, 10:03   #21 (permalink)
Member: 229358
Thanks Meter: 12
i want to reset screen lock need to keep user data , how can i do that ???
Old 07-21-2017, 11:59   #22 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
No way. Phone with encrypted user data.
Old 07-23-2017, 09:20   #23 (permalink)
eivelice's Avatar
Member: 388962
Sonork: 100.1637202
Thanks Meter: 264
hi sir andrew, i have problem, i am using windows 10 64 bit,
my laptop is i5 8 gig ram,
when i open the new exe it is slow and hanging.
when i try to repair imei of d852, it is not responding and hang.
anyway to fix this?
Old 07-23-2017, 12:43   #24 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
anyway to fix this?
Send to me in PM your dongle serial number.
Old 07-24-2017, 00:25   #25 (permalink)
Member: 2739856
Good day people!!!
I need your assistance unlocking my LG stylos 2 plus locked to T-Mobile US. Imei: 355790082740090. It has a pre installed unlock app however, it gives error response when permanent unlock icon is clicked. May the Almighty reward you bountifully for your good as u assist with the unlocking . Ameen.
Old 07-26-2017, 02:13   #26 (permalink)
Member: 2609253
M250F Repair IMEI Dont work!!
Old 07-26-2017, 11:50   #27 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
Hi,
Today we send to you in PM beta with fix.
The Following User Says Thank You to andrew_tm For This Useful Post:
Old 07-26-2017, 16:47   #28 (permalink)
Member: 2609253
Hi,
I await you PM. Thanks andrew_tm.
Old 07-26-2017, 19:22   #29 (permalink)
Member: 180148
Thanks Meter: 48
LG M210 give me errors ...
LG M210 FRP
z3x show me ext4 error
Init EXT4 ...
Laf flash ext4 error: incorrect superblock magic
Error reset locks
Elapsed: 2 secs. --> (v9.38)
Old 07-26-2017, 21:32   #30 (permalink)
Member: 2609253
andrew_tm:
Repair IMEI M250F Ok, thanks for your support.
The Following User Says Thank You to Ras3ck For This Useful Post:
Page generated in 0.28753 seconds with 8 queries
