Old 07-27-2017, 09:39   #31 (permalink)
Member: 2739426
Originally Posted by Ras3ck View Post
M250F Repair IMEI Dont work!!
M250N Repair imei same dont work!
Old 07-27-2017, 09:39   #32 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 2,902
Hi,
https://mega.nz/#!y15ATAYR!wa46wSiL8...ZVuOrJT1D6_mm0
1. Download
2. Put in LG Tool dir
3. Run and try repair IMEI
post result
The Following User Says Thank You to andrew_tm For This Useful Post:
Old 07-27-2017, 10:01   #33 (permalink)
Member: 2739426
This works well!
IMEI Repair Done
Big Thanks !!
The Following User Says Thank You to 3252pbsz For This Useful Post:
Old 08-03-2017, 21:12   #34 (permalink)
Member: 2665448
Sonork: innocentsoul008
Thanks Meter: 3
hi sir andrew_tm is there any way to unlock lg h901.
the unlock option is disable for that model should i try with different model?
Old 08-03-2017, 21:21   #35 (permalink)
nelmaster_vc's Avatar
Member: 983297
Thanks Meter: 41
Try unlock M153 show unlock but not work , phone still locked
Old 08-03-2017, 21:31   #36 (permalink)
Member: 1001056
Thanks Meter: 4
Select lg h850 to unlock lg m151 , but after unlock , no signal , emergency call only
8/2/2017 12:11:19 AM: LG 2-3G Tool v9.38
8/2/2017 12:11:19 AM: supported models: 1513
8/2/2017 12:13:08 AM: Mode: Normal
8/2/2017 12:13:08 AM: Model: LGM151AT
8/2/2017 12:13:08 AM: Build version: Jan 15 201719:35:19Dec 13 201623:00:00LGM151AT
8/2/2017 12:13:08 AM: SW Version: MPSS.JO.2.0.c1.2-00007-8909_GEN_PACK-1.80814.1_80783.1
8/2/2017 12:13:08 AM: IMEI: 35457608032902-3
8/2/2017 12:13:08 AM: BlueTooth Address: 00:00:00:00:00:00
8/2/2017 12:13:08 AM: Phone Code:
8/2/2017 12:13:08 AM: Elapsed: 1 secs. --> (v9.38)
8/2/2017 12:13:08 AM: Checking phone at
8/2/2017 12:13:08 AM: COM9
8/2/2017 12:13:09 AM: Detected ID:
8/2/2017 12:13:09 AM: 0000100C (MSM8909)
8/2/2017 12:13:09 AM: SW Version:
8/2/2017 12:13:09 AM: MPSS.JO.2.0.c1.2-00007-8909_GEN_PACK-1.80814.1_80783.1
8/2/2017 12:13:09 AM: Reading ESN...
8/2/2017 12:13:09 AM: OK
8/2/2017 12:13:09 AM: Read SPC...
8/2/2017 12:13:09 AM: Unlock SPC...
8/2/2017 12:13:09 AM: Backuping RFNV...
8/2/2017 12:13:21 AM: OK
8/2/2017 12:13:21 AM: Backuping Feature Mask...
8/2/2017 12:13:21 AM: Backuping NV Item...
8/2/2017 12:14:05 AM: OK
8/2/2017 12:14:05 AM: Backuping NV Item SIM1...
8/2/2017 12:14:48 AM: OK
8/2/2017 12:14:48 AM: Backuping NV Item SIM2...
8/2/2017 12:15:29 AM: OK
8/2/2017 12:15:29 AM: Backuping Provisioning Item Files...
8/2/2017 12:15:41 AM: OK
8/2/2017 12:15:41 AM: Phone mode is
8/2/2017 12:15:41 AM: NORMAL
8/2/2017 12:15:41 AM: Switch to DOWNLOAD mode
8/2/2017 12:16:17 AM: Phone detected!
8/2/2017 12:16:17 AM: Read security zone...
8/2/2017 12:16:18 AM: Model name: LG-M151
8/2/2017 12:16:18 AM: Software verion: M15110a
8/2/2017 12:16:18 AM: Android verion: 6.0.1
8/2/2017 12:16:18 AM: Target operator: GLOBAL
8/2/2017 12:16:18 AM: Target country: CA
8/2/2017 12:16:18 AM: IMEI: 354576080329023
8/2/2017 12:16:19 AM: Save part1...
8/2/2017 12:16:19 AM: done
8/2/2017 12:16:20 AM: Save part2...
8/2/2017 12:16:20 AM: done
8/2/2017 12:16:20 AM: Save part3...
8/2/2017 12:16:21 AM: Sec zone saved: ..\Backup\H850_354576080329023_02082017_001619.lgs b1
8/2/2017 12:16:21 AM: Write security zone...
8/2/2017 12:16:21 AM: Erase part1...
8/2/2017 12:16:21 AM: done
8/2/2017 12:16:21 AM: Erase part2...
8/2/2017 12:16:21 AM: Erase part3...
8/2/2017 12:16:21 AM: Reboot...
8/2/2017 12:17:21 AM: Phone detected!
8/2/2017 12:17:21 AM: Reading QCN file...
8/2/2017 12:17:21 AM: OK
8/2/2017 12:17:21 AM: Port open fail COM9
8/2/2017 12:17:21 AM: Elapsed: 253 secs. --> (v9.38)
8/2/2017 12:20:22 AM: Port already opened!
8/2/2017 12:20:22 AM: Elapsed: 0 secs. --> (v9.38)
8/2/2017 12:20:31 AM: Unable to get comport information , check system
8/2/2017 12:20:33 AM: Unable to get comport information , check system
8/2/2017 12:20:49 AM: Unable to get comport information , check system
8/2/2017 12:20:54 AM: LG 2-3G Tool v9.38
8/2/2017 12:20:54 AM: supported models: 1513
8/2/2017 12:21:34 AM: Select ComPort or use Search Phone button!
8/2/2017 12:21:34 AM: Elapsed: 0 secs. --> (v9.38)
8/2/2017 12:21:39 AM: Unable to get comport information , check system
i double check the phone usb connection , i forget to change the usb connection charging only to file transfer , it interrupt unlock , so , i set it to file transfer and unlock it again
8/2/2017 12:22:26 AM: LG 2-3G Tool v9.38
8/2/2017 12:22:26 AM: supported models: 1513
8/2/2017 12:22:44 AM: Mode: Normal
8/2/2017 12:22:44 AM: Model: LGM151AT
8/2/2017 12:22:44 AM: Build version: Jan 15 201719:35:19Dec 13 201623:00:00LGM151AT
8/2/2017 12:22:44 AM: SW Version: MPSS.JO.2.0.c1.2-00007-8909_GEN_PACK-1.80814.1_80783.1
8/2/2017 12:22:45 AM: IMEI: 00000000000000-0
8/2/2017 12:22:45 AM: BlueTooth Address: 00:00:00:00:00:00
8/2/2017 12:22:45 AM: Phone Code: default
8/2/2017 12:22:45 AM: Elapsed: 1 secs. --> (v9.38)
8/2/2017 12:22:45 AM: Checking phone at
8/2/2017 12:22:45 AM: COM9
8/2/2017 12:22:45 AM: Detected ID:
8/2/2017 12:22:45 AM: 0000100C (MSM8909)
8/2/2017 12:22:45 AM: SW Version:
8/2/2017 12:22:45 AM: MPSS.JO.2.0.c1.2-00007-8909_GEN_PACK-1.80814.1_80783.1
8/2/2017 12:22:45 AM: Reading ESN...
8/2/2017 12:22:45 AM: OK
8/2/2017 12:22:45 AM: Read SPC...
8/2/2017 12:22:45 AM: Unlock SPC...
8/2/2017 12:22:45 AM: Backuping RFNV...
8/2/2017 12:22:59 AM: OK
8/2/2017 12:22:59 AM: Backuping Feature Mask...
8/2/2017 12:22:59 AM: Backuping NV Item...
8/2/2017 12:23:42 AM: OK
8/2/2017 12:23:42 AM: Backuping NV Item SIM1...
8/2/2017 12:24:25 AM: OK
8/2/2017 12:24:25 AM: Backuping NV Item SIM2...
8/2/2017 12:25:08 AM: OK
8/2/2017 12:25:08 AM: Backuping Provisioning Item Files...
8/2/2017 12:25:22 AM: OK
8/2/2017 12:25:22 AM: Phone mode is
8/2/2017 12:25:22 AM: NORMAL
8/2/2017 12:25:22 AM: Switch to DOWNLOAD mode
8/2/2017 12:26:03 AM: Phone detected!
8/2/2017 12:26:03 AM: Read security zone...
8/2/2017 12:26:04 AM: Model name: LG-M151
8/2/2017 12:26:04 AM: Software verion: M15110a
8/2/2017 12:26:04 AM: Android verion: 6.0.1
8/2/2017 12:26:04 AM: Target operator: GLOBAL
8/2/2017 12:26:04 AM: Target country: CA
8/2/2017 12:26:04 AM: IMEI: 000000000000000
8/2/2017 12:26:05 AM: Save part1...
8/2/2017 12:26:05 AM: done
8/2/2017 12:26:06 AM: Save part2...
8/2/2017 12:26:06 AM: done
8/2/2017 12:26:06 AM: Save part3...
8/2/2017 12:26:07 AM: Sec zone saved: ..\Backup\H850_000000000000000_02082017_002605.lgs b1
8/2/2017 12:26:07 AM: Write security zone...
8/2/2017 12:26:07 AM: Erase part1...
8/2/2017 12:26:07 AM: done
8/2/2017 12:26:07 AM: Erase part2...
8/2/2017 12:26:07 AM: Erase part3...
8/2/2017 12:26:07 AM: Reboot...
8/2/2017 12:27:08 AM: Phone detected!
8/2/2017 12:27:08 AM: Reading QCN file...
8/2/2017 12:27:08 AM: OK
8/2/2017 12:27:08 AM: Checking phone at
8/2/2017 12:27:08 AM: COM9
8/2/2017 12:27:09 AM: Detected ID:
8/2/2017 12:27:09 AM: 0000100C (MSM8909)
8/2/2017 12:27:09 AM: SW Version:
8/2/2017 12:27:09 AM: MPSS.JO.2.0.c1.2-00007-8909_GEN_PACK-1.80814.1_80783.1
8/2/2017 12:27:09 AM: Unlock SPC...
8/2/2017 12:27:09 AM: OK
8/2/2017 12:27:09 AM: Checking paths...
8/2/2017 12:27:09 AM: Restoring EFS Backup...
8/2/2017 12:27:22 AM: OK
8/2/2017 12:27:22 AM: Restoring NV Items...
8/2/2017 12:27:33 AM: OK
8/2/2017 12:27:33 AM: Restoring NV Item SIM1...
8/2/2017 12:27:33 AM: Restoring NV Item SIM2...
8/2/2017 12:27:33 AM: Restoring Provisioning Item Files...
8/2/2017 12:27:37 AM: OK
8/2/2017 12:27:37 AM: Unlock done!
8/2/2017 12:27:37 AM: Elapsed: 292 secs. --> (v9.38)
8/2/2017 12:28:01 AM: Repair IMEI...
8/2/2017 12:29:03 AM: Search LG Modem port...
8/2/2017 12:29:03 AM: Detected LG Modem port at COM8
8/2/2017 12:29:03 AM: Repair done!
8/2/2017 12:29:03 AM: Elapsed: 61 secs. --> (v9.38)
this time is unlock and i repair the imei , unfortunately , it did not pick up any signal , EMERGENCY CALLS ONLY
what can i do ????? HOW CAN I GET SIGNAL ?????????????
i check my back up folder , i see there is 2 files there
1. H850_000000000000000_02082017_002605.lgsb1
2. H850_000000000000000_MPSS.JO.2.0.c1.2-00007-8909_GEN_PACK-1.80814.1_80783.1_02082017_002245.qcn
WHAT I CAN I DO WITH THESE 2 FILES ?
Old 08-04-2017, 06:04   #37 (permalink)
Member: 2712875
LG 2-3G Tool v9.38
Mode: Emergency
Model: K535
Read info...
Model name: LG-K535
Software verion: K53520b
Android verion: 7.0
Target country: COM
IMEI: 359383070262578
Elapsed: 4 secs. --> (v9.38)
Mode: Emergency
Model: K535
Read info...
Model name: LG-K535
Android verion: 7.0
Target country: COM
Phone mode is DOWNLOAD
Start FRP remove...
Model name: LG-K535
Android verion: 7.0
Target country: COM
Init EXT4 ...
Save EXT4...
FRP Reset Done.
Elapsed: 82 secs. --> (v9.38)
Mode: Emergency
Model: K535
Read info...
Model name: LG-K535
Android verion: 7.0
Target country: COM
Elapsed: 5 secs. --> (v9.38)
Start FRP remove...
Model name: LG-K535
Android verion: 7.0
Target country: COM
Init EXT4 ...
Restore data detected!
Save EXT4...
FRP Restore Done!
Elapsed: 41 secs. --> (v9.38)
but phone still locked frp
Old 08-04-2017, 08:47   #38 (permalink)
Member: 2665448
Thanks Meter: 3
sir will you help me i have phone in hand lg h901 want to unlock it
it is locked by T-mobile
Old 08-07-2017, 22:14   #39 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 2,902
No solutions for your phone.
Old 08-08-2017, 00:42   #40 (permalink)
Member: 2638134
lg ls676 lgls775 por favor dice siempre sim invalido
Old 09-02-2017, 21:32   #41 (permalink)
Member: 2740258
Can't flash .tot to LS777, I get:
Laf cmd error: LAF_CMD_WRITE fail[LAF_ERROR_UNKNOWN[80000121]]
Old 09-02-2017, 21:56   #42 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 2,902
You can't flash read tot in phone with signed firmware. Use original tot.
Old 09-07-2017, 07:19   #43 (permalink)
Member: 2740258
I would but is not available for that phone.
Old 09-08-2017, 17:51   #44 (permalink)
Member: 2754701
lg k371 android 7 supported?
Old 09-08-2017, 18:00   #45 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 2,902
How function?
Page generated in 0.33654 seconds with 7 queries
