Old 08-28-2017, 20:14   #31 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,063
Originally Posted by maksim78 View Post
Please add LG G6 TMO Support! H872
Select H870. Unlock not possible.
Old 08-28-2017, 20:20   #32 (permalink)
Member: 1063583
Thanks Meter: 3
I was able to use H873 to repair IMEI but unlock doesn't work. Will unlock be supported in future releases? Thanks!
Old 08-28-2017, 20:24   #33 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,063
Please post LG H873 log.
Unlock for TMobile device not possible. Use Device Unlock App from device menu.
Old 09-05-2017, 12:35   #34 (permalink)
khunglong0401's Avatar
Member: 412395
Thanks Meter: 18
Good update Z3X TEAM
Old 09-06-2017, 16:37   #35 (permalink)
Member: 2582877
Thanks Meter: 5
Suporte LG-M700? FRP 7.1.1 ?
Old 09-06-2017, 20:46   #36 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,063
Try select H870 and make FRP reset. Post result.
Old 09-08-2017, 13:07   #37 (permalink)
Member: 2582877
Thanks Meter: 5
Unable to get comport information , check system
LG 2-3G Tool v9.36
supported models: 1452
Select ComPort or use Search Phone button!
Elapsed: 0 secs. --> (v9.36)
Mode: Emergency
Model: H870
Read info...
Laf cmd error: invalid LAF protocol.
Laf read info error.
Elapsed: 1 secs. --> (v9.36)
Phone mode is DOWNLOAD
Start reset FRP...
Error reset locks
Old 09-08-2017, 13:23   #38 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,063
Today I recompile software and send you link in PM.
Old 09-08-2017, 13:26   #39 (permalink)
Member: 2582877
Thanks Meter: 5
Ok, I'm waiting, thank you so much for help.
Old 09-08-2017, 21:06   #40 (permalink)
Member: 2582877
Thanks Meter: 5
I've tried it in various ways until it's easier to use and recovery utility, but since when I tried with the H870 model it just came out just like in the picture
I know you have a solution, but why did this happen?
Old 09-08-2017, 21:08   #41 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,063
How operation you make with phone?
Please post logs.
Old 09-08-2017, 21:21   #42 (permalink)
Member: 2582877
Thanks Meter: 5
Please post logs.
I used this video, for example,
https://ruclip.com/video/BEyIfs2lTEU...ndroid-70.html
after you enter google, you go into "contacts" and type it "*#546368#*700#" after, SVC Menu/LDB , Go enalbe "USB Debugging", I use code in ADB terminal
adb devices
adb shell content insert --uri content://settings/secure --bind name:s:user_setup_complete --bind value:s:1
Unfortunately the customer came to get the device and I take it the way it was, but I will do this test in the next device and step feedback
Old 09-08-2017, 21:26   #43 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,063
If you use this method why with problem comes to me?
Send to me in PM phone IMEI and I check firmware for your phone and region. Maybe need reflash phone.
I already send beta to you in PM.
Old 09-08-2017, 21:59   #44 (permalink)
Member: 2582877
Thanks Meter: 5
I did not know that I had to remove with this method, as I was having time and the client said that I came to get earlier, so I did not want to lose the service,
I always look for a solution with box usage, and whenever I can pass feedback.
Old 09-30-2017, 14:42   #45 (permalink)
Member: 2709982
Sonork: 100.1677638
Can z3x unlock LG LS997?
Page generated in 0.33607 seconds with 7 queries
