11-04-2017, 14:52 | #76 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Quote:
I've also read somewhere that you can "flash" some parameters in download mode to activate the diag port. I'll post it if I find it again. Not sure if you could "flash" these in download mode, instead of entering it through root shell: echo 1 > /sys/class/sec/switch echo 1 > /sys/class/sec/switch/uart_en echo 1 > /sys/devices/platform/lg_diag_cmd/diag_enable setprop sys.usb.config acm,diag,mtp,adb Also it might be posssbile to trigger the "activity" corresponding to these keypad commands: 3845#*<model#># - Test menu ATT, TMO, INT 5689#*<model#># - Test menu SPR ##3424# - SPR (enable ADB, select Charge Phone mode) ##TEST# - SPR Test menu ##228378 + Send - Test menu VZW *#546368#*<model#># - Test menu Generic (LGMENU) 277634#*# - Test menu Generic (Port check test, set enabled, reconnect device) | |
11-04-2017, 15:10 | #77 (permalink) | |
Product Supporter Join Date: Feb 2007 Location: Europe
Member: 445973 Status: Offline Thanks Meter: 3,489 | Quote:
The Following User Says Thank You to andrew_tm For This Useful Post: |
11-04-2017, 16:33 | #81 (permalink) | |
11-04-2017, 19:48 | #82 (permalink) |
No Life Poster Join Date: May 2009 Location: USA/NY
Member: 1025079 Status: Offline Thanks Meter: 311 | Andrew problem is with ATT Firmware been signed, can't find any where factory file. and my devices most of them are bad lcd can't even reset using combination key, and looking at delete all personal data. |
11-05-2017, 12:48 | #84 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Pakistan
Member: 123458 Status: Offline Sonork: 100.1594535 Thanks Meter: 3,421 | please help me here http://forum.gsmhosting.com/vbb/f453...ls676-2283107/ |
11-05-2017, 13:10 | #85 (permalink) | |
11-14-2017, 05:54 | #90 (permalink) |
Freak Poster Join Date: May 2016
Member: 2575858 Status: Offline Thanks Meter: 20 | NO LUCK LG STYLO 3 SPRINT SIM UNLOCK I ENABLED DIAG ##3424# ANY IDEAS???? TRIED M470 & M470F Mode: Emergency . Model: M470 . Read info... . Laf Protocol: 01000005 . Model name: LG-LS777 . Software verion: LS777ZV8 . Android verion: 7.0 . Target operator: SPR . Target country: US . IMEI: 354234084360590 . Elapsed: 3 secs. --> (v9.43) . Mode: Normal . Model: . Build version: x\f1\'f0~ . \f0 SW Version: . IMEI: BAD IMEI . IMEI2: 70000000000000-3 . BlueTooth Address: 00:00:00:7E:BB:01 . Phone Code: . Elapsed: 4 secs. --> (v9.43) . Mode: Emergency . Model: M470F . Read info... . Laf Protocol: 01000005 . Model name: LG-LS777 . Software verion: LS777ZV8 . Android verion: 7.0 . Target operator: SPR . Target country: US . IMEI: 354234084360590 . Elapsed: 3 secs. --> (v9.43) . Mode: Normal . Model: LS777ZV8 . Build version: Oct 24 201720:32:11Sep 07 201723:00:00LS777ZV8 . SW Version: MPSS.TA.2.3.c4-00002-8940_GEN_PACK-1.84083.1.115268.1 . IMEI: 35423408436059-0 . IMEI2: 00000000000000-0 . BlueTooth Address: 00:00:01:02:26:00 . Phone Code: . Elapsed: 1 secs. --> (v9.43) . . Checking phone at COM14 . Detected ID: 0000100E (MSM8952) . SW Version: MPSS.TA.2.3.c4-00002-8940_GEN_PACK-1.84083.1.115268.1 . Reading ESN... OK . Read SPC... . Unlock SPC... error . Elapsed: 1 secs. --> (v9.43) |
