Old 07-30-2015, 10:49   #1 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 177,883
LG 2-3G Tool v8.0 released. LG L90 Dual, G2 mini, G3 Beat, G3S Dual
Added :
- support D150 (direct unlock, imei repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
- support D157 (direct unlock, imei master/slave repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
- support D157F (direct unlock, imei master/slave repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint) thanks to toninhosantos
- support D410 (direct unlock, imei master/slave repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
- support D410H (direct unlock, imei master/slave repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
- support D410HN (direct unlock, imei master/slave repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint) thanks to toninhosantos - world first!
- support D410N (direct unlock, imei master/slave repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
- support D618 imei master/slave repair
- support D722AR (direct unlock, imei repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
- support D722PA (direct unlock, imei repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
- support D724 (direct unlock, imei master/slave repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
- support D727 (direct unlock, imei repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
- support D728 (direct unlock, imei master/slave repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
- support D729 (direct unlock, imei master/slave repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
- support D856 (direct unlock, imei master/slave repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
- support D857 (direct unlock, imei master/slave repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
- support D858 (direct unlock, imei master/slave repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
- support D858HK (direct unlock, imei master/slave repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
- support D859 (direct unlock, imei master/slave repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
- support H440AR (direct unlock, imei repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
- support H443 (direct unlock, imei repair, qcn read/write, nvm read/write, sec zone read/write/reset, hint)
* some bug fix.
+ new qcn files.
Multi-language interface - for translate use Z3X LG 2-3G Tool (Z3X LG 2-3G Tool)
The Following 30 Users Say Thank You to blang For This Useful Post:
Old 07-30-2015, 11:23   #2 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,396
blang z3x lg firmware not for shell
plz firmware update
Old 07-30-2015, 11:49   #3 (permalink)
kamal_singla's Avatar
Member: 2211790
Thanks Meter: 4,123
any solution of LG U400 enter unlock code....
Old 07-30-2015, 13:33   #4 (permalink)
nduka's Avatar
Member: 1943439
Sonork: 100.1669578
Thanks Meter: 191
booom,z3x master of all boxes
Old 07-30-2015, 14:38   #5 (permalink)
ALI_MAFIA's Avatar
Member: 537240
Sonork: 100.1660416
Thanks Meter: 229
need flash support F160LV,
Old 07-30-2015, 14:42   #6 (permalink)
bedel's Avatar
Member: 321176
Sonork: 100.1640958
Thanks Meter: 48
Pleas Can Share Download Link.
Thank in advance.
bedel
Old 07-30-2015, 15:17   #7 (permalink)
Member: 300408
Thanks Meter: 8
help unlock ms345 lg leon next update
Old 07-30-2015, 16:58   #8 (permalink)
Cheater -Don't Deal with him-
Member: 1965371
Thanks Meter: 440
Thank you sir Great Update
Old 07-30-2015, 19:42   #9 (permalink)
Yong Vannak's Avatar
Member: 770210
Thanks Meter: 44
good update please add alots modell
Old 07-30-2015, 19:59   #10 (permalink)
Member: 1263334
Sonork: 100.1651849
Thanks Meter: 24
Leon 4G LTE MS345 Fail to Unlock
[LG 2-3G Tool v8.0
supported models: 1039
Check Android Lollipop...
Stage #1 OK
Mode: Normal
Model: EAAAANVZ
Build version: Apr 17 201512:00:54Mar 10 201506:00:00EAAAANVZ
SW Version: MPSS.DPM.2.0.c11-00014-M8936FAAAANUZM-1
IMEI:
BlueTooth Address: 00:00:00:00:00:00
Phone Code: default
Elapsed: 1 secs. --> (v8.0)
This phone are not supported , or can be unlocked by patch!
Old 07-30-2015, 20:24   #11 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,430
Originally Posted by Nutty70 View Post
[LG 2-3G Tool v8.0
Stage #1 OK
Mode: Normal
Model: EAAAANVZ
IMEI:
Phone Code: default
We not support unlock MS345.
Old 07-31-2015, 01:50   #12 (permalink)
Member: 1691165
Thanks Meter: 5
Great update. Please provide support for H811 and H631 (unlock) soon.
Old 07-31-2015, 02:40   #13 (permalink)
Member: 172567
Thanks Meter: 57
Something wrong with D410HN, can't read correct imei sector
LG 2-3G Tool v8.0
Reading timeout, check cable
Error Code: ReadInfo,1,1
Elapsed: 2 secs. --> (v8.0)
Mode: Normal
Model:
Build version: x~
SW Version:
IMEI: BAD IMEI
IMEI2: 70000000000000-3
BlueTooth Address: 00:00:00:7E:BB:01
Phone Code:
Elapsed: 0 secs. --> (v8.0)
And the IMEI is correct on phone, provably bad parameteres for reading (tested with others D410 models, allways same result)
Old 07-31-2015, 19:41   #14 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,430
How android version in your phone?
Old 07-31-2015, 20:43   #15 (permalink)
Member: 2078045
Thanks Meter: 142
lg d625 support ??????????????????????
Page generated in 0.37964 seconds with 7 queries
