08-07-2015, 12:05 | #24 (permalink) | |
Product Supporter Join Date: Feb 2007 Location: Europe
Member: 445973 Status: Offline Thanks Meter: 3,489 | Quote:
I test in user using team viewer. Yes we can repair imei without root. No need unlock bootloader. -- | |
08-07-2015, 12:15 | #26 (permalink) | |
No Life Poster Join Date: Apr 2005 Age: 57
Member: 137980 Status: Offline Thanks Meter: 168 | Quote:
LG 2-3G Tool v8.1 supported models: 1040 Check Android Lollipop... Stage #1 ERROR Stage #2 OK Stage #3 OK Android Lollipop detected Mode: Normal Model: LGH811AT Build version: Jun 1 201515:07:33Apr 23 201518:00:00LGH811AT SW Version: MPSS.BO.2.5.c3-00070-M8992FAAAANAZM-1 IMEI: 35239207028410-9 BlueTooth Address: 00:00:00:00:00:00 Phone Code: SPC: 000000 Elapsed: 74 secs. --> (v8.1) Check adb server status... Try kill add server... ERROR Device not found! Enable USB debugging: 1. Menu -> General -> About phone -> Common -> Software Information -> 7 times click in Build Number. 2. Menu -> General -> Developer options -> Enable USB debugging. Elapsed: 8 secs. --> (v8.1) Check adb server status... OK Found 1 device(s) Device name: LG-H811 Firmware version: Android release: 5.1 Platform: msm8992 Start root... Send exploit: OK! Install exploit: OK! Root status: ERROR!su /system/bin/sh: su: not found 127|shell@p1:/ $ Elapsed: 302 secs. --> (v8.1) Check Android Lollipop... Stage #1 OK Mode: Normal Model: LGH811AT Build version: Jun 1 201515:07:33Apr 23 201518:00:00LGH811AT SW Version: MPSS.BO.2.5.c3-00070-M8992FAAAANAZM-1 IMEI: 35239207028410-9 BlueTooth Address: 00:00:00:00:00:06 Phone Code: SPC: 000000 Elapsed: 0 secs. --> (v8.1) Check Android Lollipop... Stage #1 OK Mode: Normal Model: LGH811AT Build version: Jun 1 201515:07:33Apr 23 201518:00:00LGH811AT SW Version: MPSS.BO.2.5.c3-00070-M8992FAAAANAZM-1 IMEI: 35239207028410-9 BlueTooth Address: 00:00:00:00:00:06 Phone Code: SPC: 000000 Elapsed: 0 secs. --> (v8.1) Checking phone at COM17 Detected ID: 00001001 (MSM8994) SW Version: MPSS.BO.2.5.c3-00070-M8992FAAAANAZM-1 Reading ESN... OK Read SPC... SPC: 000000 Unlock SPC... OK Backuping RFNV... OK Backuping Feature Mask... OK Backuping NV Item... OK Backuping NV Item SIM1... OK Backuping NV Item SIM2... OK Backuping Provisioning Item Files... OK Phone mode is NORMAL Switch to DOWNLOAD mode Phone detected! Read GPT... done Read security zone... done Sec zone saved: ..\Backup\H815LA_352392070284109_07082015_164111.l gsb1 Write security zone... done Phone detected! Reading QCN file... OK Checking phone at COM17 Detected ID: 00001001 (MSM8994) SW Version: MPSS.BO.2.5.c3-00070-M8992FAAAANAZM-1 Unlock SPC... OK Checking paths... OK Restoring EFS Backup... OK Restoring NV Items... OK Restoring NV Item SIM1... OK Restoring NV Item SIM2... OK Restoring Provisioning Item Files... OK Unlock done! Elapsed: 280 secs. --> (v8.1) Check Android Lollipop... Stage #1 OK Mode: Normal Model: LGH811AT Build version: Jun 1 201515:07:33Apr 23 201518:00:00LGH811AT SW Version: MPSS.BO.2.5.c3-00070-M8992FAAAANAZM-1 IMEI: 35239207028410-9 BlueTooth Address: 42:00:00:00:01:00 Phone Code: SPC: 000000 Elapsed: 0 secs. --> (v8.1) Not supported for this phone! now phone imei show 0 how to fix please help | |
The Following User Says Thank You to nilan For This Useful Post: |
08-07-2015, 13:14 | #30 (permalink) |
Member: 445973 Status: Offline Thanks Meter: 3,489 | We plain rewrite helps in LG software. I this in next month we make this. P.S. I not see problem if you press unlock and software write in log: phone must be rooted, the you must root phone. -- |
