01-19-2017, 22:10 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Jamaica
Member: 244159 Status: Offline Thanks Meter: 16 | LG B470 Unlock |
The Following User Says Thank You to HERBERT23 For This Useful Post: |
02-27-2017, 16:32 | #12 (permalink) |
No Life Poster Join Date: Apr 2004 Location: MOON
Member: 60899 Status: Offline Thanks Meter: 792 | i did it myself with my old v-box also you can find in spanish forums the instructions, here is log: select LGC395, select correct phone: no, no press unlock Phone type selected : LGC395 IMEI : 014564-00-868541-3 Bluetooth Addr : DC:0B:34:2E:1F:86 Phone version : LGB470-QSC6270-V10c-JAN-11-2016-ATT-US Compilation info : Jan 11 201614:27:36JAN 11 201622:00:00LGB470 ------- Unlocking ... Switching phone to DL MODE, please wait ... OK Loading main loader ... OK Executing loader, please wait ... OK Initialing NAND ... OK Continue operation ... Making backup file ... OK Decrypting security zone ... OK Writing security zone ... OK Restarting phone, please wait ... Can't switch phone to NORMAL mode and unlocked here is post from spanish forum via google translate: Hello friends, I tell you to look everywhere for the way to release this phone, LGMS450, both in this forum and others, and I could not find another solution that was not buying codes. Here I bring the solution with this fabulous box that is the VYGIS. - They do it with the LGQ_2_13SD module by selecting the LGC395. - Connect the phone on, select the model and give it "connect port" and then "connect phone" IMPORTANT: The program asks you twice if you want to select the correct phone and twice have to select "NO" - Here you go The trick, when you give "NO" the second you see the phone reboot but we have all the options enabled in the program. - Disconnect the handset and manually set it to "download mode", by pressing the 2 and 5 keys and the power on. On the phone say "S / W Upgrade", do not connect it yet. - Select "Direct Unlock" in the program, connect the phone and the release process will continue. - It will give an error at the end "Writing signature ... Can not write signature" but ignore, the phone is already released |
03-14-2017, 09:05 | #13 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Quote:
I wonder if the B470 and the model LGC395 trick might work with other boxes too like Z3X or Octo? If anyone's willing to try and post result then at least it could be added in the Z3X menu. | |
04-19-2017, 15:13 | #14 (permalink) |
Insane Poster Join Date: Sep 2014 Location: somewhere in the world
Member: 2262745 Status: Offline Sonork: 167687 Thanks Meter: 11 | octo box I tried it with the Octopus box and I didn't get any results. it wouldn't connect to it. Don't have the LG Z3x. Has anyone tried that? |
04-26-2017, 00:51 | #15 (permalink) | |
Yes tried it with Z3X using model LGC395 (or similar) and I just messed up the efs. lol Someone really needs to get this phone to Andrew_TM This is what I get using different boxes. Diag mode: 3945#*470# LG 2-3G Tool v9.32 Z3X supported models: 1440 Mode: Normal Model: LGB470 Build version: Jan 11 201614:27:36JAN 11 201622:00:00LGB470 SW Version: LGB470-QSC6270-V10c-JAN-11-2016-ATT-US IMEI: 35410408163134-5 BlueTooth Address: 80:5A:04:5D:2B:39 Phone Code: default Elapsed: 1 secs. --> (v9.32) LGTool Emergency Mode (2+5+Power) Connected Receiving phone info Getting phone info Model: C320 Platform: LG Qualcomm Software Platform: AMSS SDRAM Size: 128 MB NAND Flash Size: 256 MB CPU: QSC6270 Connect mode: Emergency Info received Octo Download Mode Platform: LG Qualcomm Selected port: COM3 Selected model: C440 Reading info...OK Mode: Normal Model ID: LGB470 Firmware compiled date: JAN 11 2016 Firmware compiled time: 22:00:00 Firmware released date: Jan 11 2016 Firmware released time: 14:27:36 SW Version: LGB470-QSC6270-V10c-JAN-11-2016-ATT-US IMEI: 354104-08-163134-5 Bluetooth address: 80:5A:04:5D:2B:39 Performed by 2.5.7 Software version. | |
