06-07-2015, 03:37 | #35 (permalink) |
Freak Poster Join Date: Mar 2014
Member: 2145583 Status: Offline Thanks Meter: 7 | Analising USB Configuration... Connect powered off MTK Device to USB cable... You have 20 seconds. USB Serial COM Attached to system... COM Port short name : COM42 COM Port full name : LGE AndroidNet USB Serial Port COM Port hardware id : USB\VID_1004&PID_61F1&REV_0216&MI_02 Open port COM42... Send start CMD commands...fail Enter to Download mode again. Booting FAIL USB Serial COM Attached to system... COM Port short name : COM42 COM Port full name : LGE AndroidNet USB Serial Port COM Port hardware id : USB\VID_1004&PID_61F1&REV_0216&MI_02 Open port COM42...fail , error code is :2 help please!!! |
06-07-2015, 05:38 | #36 (permalink) |
Freak Poster Join Date: Oct 2011 Location: Morocco
Member: 1668346 Status: Offline Sonork: 100.1648020 Thanks Meter: 101 | CAN YOU HELP ME SIR. IF I HAVE ERROR IN SELECTED BOOT.bin FILE GIVE US GOOD boot.bin FILE FOR LG E960. THANK YOU Selected model is:LG E960 Using COMPORT: 160 Connecting to target... Error :receive rsp:unknown error. QFastDL Ping Failed... Downloading image FAILED Using COMPORT: 160 Connecting to target... QFastDL Ping Success... Sending Loader... OK Waiting for Loader... Detected APRG instance: COM160 , Qualcomm HS-USB QDLoader 9008 (COM160) Connect OK Configuring protocol... OK Loader mode are EMMC. Set security mode off... OK Opening multi image transfer mode... Timeout! Downloading image FAILED |
06-08-2015, 21:25 | #40 (permalink) |
Freak Poster Join Date: Sep 2004 Location: Toronto Age: 41
Member: 84323 Status: Offline Thanks Meter: 15 | Would I be able to take advantage of the QS-LOADER fix to repair a N910 ? If I were able to extract a boot file from a working device and write it over to a non-working model ? BR |
06-11-2015, 21:52 | #42 (permalink) |
No Life Poster Join Date: Apr 2013 Location: PT
Member: 1919025 Status: Offline Sonork: 100.1657804 Thanks Meter: 417 | Totally 100% working and extremelly easy to use Selected model is:LG E440 Boot is not selected! Using COMPORT: COM30 Analising USB Configuration... Connect powered off MTK Device to USB cable... You have 20 seconds. USB Serial COM Attached to system... COM Port short name : COM31 COM Port full name : LGE AndroidNet USB Serial Port COM Port hardware id : USB\VID_1004&PID_61F1&REV_0100&MI_02 Open port COM31... Send start CMD commands...done Read HW_CODE...done HW_CODE: 0x6575 Read HW_SW_VER...done HW_SUB_CODE: 0x8A00 HW_VER: 0xCB00 SW_VER: 0xE201 GetEntryRegion...done Disable WDT...done Send DA Agent...done Jump to DA...done Wait DA response...done Send storage device and external ram device config...done Detect NAND Flash...done Get target inforamtion...done Booting OK EMMC Config: EMMC rpmb size: 2048kb EMMC boot1 size: 2048kb EMMC boot2 size: 2048kb EMMC user area size: 3696 Mb Read logical partitions info...done Totally detected partitions: 28 Searching security blocks...ok Reading Security...done IMEI A: 35263606069415 IMEI B: 35030526000000 Bluetooth address:F8A9D0E4D444 Wi-Fi MAC address:CCFA00E063E1 LG SVN1: LGE440AT-01-V10c-268-06-TM3-APR-15-2014+0 LG SVN2: LGE440AT-00-V10c-TM3-PT-APR-15-2014+0 NCK: 9481743040289149 NSCK: 1836621277321716 SPCK: 3825978740435166 CCK: 3702084558303818 SIM: 7364133154319128 HCK: 0000000000000000 Backup are saved into Backups\Backup__35263606069415_SEC.BIN done Read Info OK |
06-11-2015, 22:28 | #43 (permalink) | |
Member: 1919025 Status: Offline Sonork: 100.1657804 Thanks Meter: 417 | Quote:
http://forum.gsmhosting.com/vbb/f453.../#post11104242 hope it helps you otherwise or in case of any doubt please just ask | |
