10-04-2016, 18:23 | #1 (permalink) |
No Life Poster Join Date: Jun 2016 Location: every ware in your hart
Member: 2590583 Status: Offline Thanks Meter: 198 | LG d722 sub debugging problem Sent from my SM-J500F using Tapatalk |
10-04-2016, 19:08 | #2 (permalink) |
Product Supporter Join Date: Feb 2007 Location: Europe
Member: 445973 Status: Offline Thanks Meter: 3,489 | For repair IMEI you no need enable usb debug. Please read connection section in manual and make next: 1. Run LG 2-3G Tool. 2. Select D722. 3. Type service menu code and enable Diag Port (service code exist in help). 4. Connect phone to PC. 5. Press Search phone button. 6. Select IMEI and press Repair button. 7. Select New Qualcomm Algo. -- |
10-04-2016, 19:40 | #4 (permalink) | |
Member: 445973 Status: Offline Thanks Meter: 3,489 | Quote:
You install LG driver? LGUnitedMobileDriver_S52MAN314AP22_ML_WHQL_Ver_3.1 4.1.exe this driver exist in support area. Try connect phone in Lg Software Mode or MTP or Charge only. PC must detect LG Port. -- | |
10-04-2016, 20:00 | #11 (permalink) |
Member: 445973 Status: Offline Thanks Meter: 3,489 | 1. Put phone in download mode(turn off phone, press vol + button and insert usb cable). 2. Reflash phone with original firmware from support area with checked: - erase user data after flash. - flash in direct mode. 3. After this Enable Diag Port and make Repair. -- |
