02-21-2016, 11:44 | #3 (permalink) |
No Life Poster Join Date: Oct 2009 Location: GRAN ALACANT SPAIN
Member: 1147852 Status: Offline Thanks Meter: 587 | In normal mode phone is not detected at all While with other tool i have full log. Maybe am doing something wrong. Can you describe connection method in normal mode? I have an lg D821 with Imei : 0 no way to fix it . From 6.0.1 i downgraded to 5.1.1 and to 4.4.4 and always getting error with other tool. The only thing i ve done with z3x lg is in the screenshot above. Best Regards. Punto-Movil |
02-21-2016, 18:17 | #6 (permalink) | |
Product Supporter Join Date: Feb 2007 Location: Europe
Member: 445973 Status: Offline Thanks Meter: 3,489 | Quote:
2. PC detect LG serial port in Device Manager? If not see you must root phone and press in software DIAG button (this enable diagnostic port). -- | |
02-22-2016, 13:49 | #7 (permalink) |
Member: 1147852 Status: Offline Thanks Meter: 587 | LG 2-3G Tool v9.0 supported models: 1116 Check adb server status... OK Device name: Nexus 5 Firmware version: Android release: 4.4 Platform: msm8974 Root status: OK! Current intefaces: mtp,adb Enable diagnostic port Device not found! Elapsed: 71 secs. --> (v9.0) not detected as adb device after this error i have to wipe device and retry every time With other tool diag port is easily and correctly enabled |
02-24-2016, 22:35 | #9 (permalink) |
Member: 1147852 Status: Offline Thanks Meter: 587 | LG 2-3G Tool v9.0 supported models: 1116 Check adb server status... OK Device name: Nexus 5 Firmware version: Android release: 5.1 Platform: msm8974 Root status: Phone not rooted! Root phone manual! Elapsed: 3 secs. --> (v9.0) Check adb server status... OK Device name: Nexus 5 Firmware version: Android release: 5.1 Platform: msm8974 Root status: OK! Current intefaces: mtp,adb Enable diagnostic port OK Elapsed: 68 secs. --> (v9.0) Check Android Lollipop... Stage #1 OK Mode: Normal Model: AAAAANAZ Build version: Jan 14 201513:18:58Sep 03 201407:00:00AAAAANAZ SW Version: M8974A-2.0.50.2.25 IMEI: 00000000000000-0 BlueTooth Address: 00:00:00:00:00:00 Phone Code: default SPC: 000000 Elapsed: 0 secs. --> (v9.0) Check Android Lollipop... Stage #1 OK Mode: Normal Model: AAAAANAZ Build version: Jan 14 201513:18:58Sep 03 201407:00:00AAAAANAZ SW Version: M8974A-2.0.50.2.25 IMEI: 00000000000000-0 BlueTooth Address: 00:00:00:00:00:06 Phone Code: default SPC: 000000 Elapsed: 0 secs. --> (v9.0) Repair IMEI... Check adb server status... OK Found 1 device(s) Device name: Nexus 5 Firmware version: Android release: 5.1 Platform: msm8974 Root status: OK! Checking phone at COM815 Detected ID: 00000FF3 (MSM8974) SW Version: M8974A-2.0.50.2.25 Reading ESN... OK Read SPC... SPC: 000000 Unlock SPC... OK Backuping RFNV... OK Backuping Feature Mask... OK Backuping NV Item... OK Backuping NV Item SIM1... OK Backuping NV Item SIM2... OK Backuping Provisioning Item Files... OK Scaning security area by HUMMER algo... Making security area diagram: -----------++---------- -----------++---------- Backup security zone... Sec zone saved: ..\Backup\D820_000000000000000_24022016_222841.lgs b1 Writing security zone... Reboot phone Phone detected! Reading QCN file... OK Checking phone at COM815 Detected ID: 00000FF3 (MSM8974) SW Version: M8974A-2.0.50.2.25 Unlock SPC... OK Checking paths... OK Restoring EFS Backup... OK Restoring NV Items... OK Restoring NV Item SIM1... OK Restoring NV Item SIM2... OK Restoring Provisioning Item Files... OK Repair IMEI1... Write IMEI 1 OK Repair done! Elapsed: 429 secs. --> (v9.0) Repair IMEI 0... Write IMEI 1 OK Done! Elapsed: 16 secs. --> (v9.0) imei still 0 |
02-24-2016, 23:07 | #11 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | try a qcn for repair for see what happen if u put imei ok try for see now with qcn C:\Program Files\Z3X\LG\LGTool\Resources\QCN supposed to change imei after give another imei.. good luck. |
